Indeed.
I just pushed a fix.
Thanks.
Curves workbench
Re: Curves workbench
Info tools seems give the legth of the circle instead the arc length.
- length.FCStd
- (4.6 KiB) Downloaded 68 times
- Capture.JPG (23.15 KiB) Viewed 1763 times
GeomInfo was first intended to display Geometry info.
But since I already added a couple of topolgy info in the text (tolerance, 2d curves), it make sense to also display edge length.
It now display : Edge Length (+ Geometry curve length if different )
- geominfo2.png (11.07 KiB) Viewed 1711 times
Please may I highlight two tooltip quirks?
1) I think the first word, displays, should be Display i.e. singular and first-letter as uppercase.
2) I think this should read: Blend surface between two curveOnSurface objects i.e. noun instead of verb, lowercase Surface and two instead of to.
These are trivial changes but beneficial.
Regards,
Neil
Regards,
Neil
Good catch. Submitted PR: https://github.com/tomate44/CurvesWB/pull/35
Merged. Thanks.
@Chris_G in the UI there is a mixed curves command but it uses combined_curves.svg. Is it possible to rename one of them?Chris_G wrote:
Edit: source: https://github.com/luzpaz/CurvesWB/blob ... rve.py#L16
There is a ./Curves/bezierCurve-2.py
This seems to be a dupe. Is that intentional? If it's a WIP, perhaps you can put it on a different branch so it doesn't pollute the main branch ?
It may be useful to put some separators in between the Curves toolbar commands. In order to group them. Or perhaps split the toolbar in to several smaller ones so that users can have the option to manipulate/reposition the toolbars to match their workflow?
In addition to the above. I've also created a PR while creating documentation on the wiki for Curves WB
https://github.com/tomate44/CurvesWB/pull/37
@GlouGlou would you be open to continue creating documentation in the wiki in regards to Curves Workbench ?GlouGlou wrote:
I will try. Could you make the templates for the empty pages, please.
