How did you determine that was?
Black screen when selecting objects from a sketch
- dcapeletti
Re: Black screen when selecting objects from a sketch
On my PC that recently crashed the issue did not appear but the old PC that I re-activated I can confirm the problem.
I have created the ticket issue #4103. Maybe we can find a way to get it reliably working when anti-aliasing is enabled.
In the output window you can enable log messages and when doing the rubber band selection this message may appear: QOpenGLFramebufferObject: Unsupported framebuffer format.
The problem is that the combination of multi-sampling and internally requested texture format are not supported by the driver and then the message is printed.
In my case the maximum allowed multi-sampling (GL_MAX_SAMPLES) is even 16 but only 8 is requested by the application but in OpenGL an error is still set. What works for me is to reduce the multi-sampling to 4.
That solved the issue for me, no more black screen.
OS: macOS Mojave (10.14)
Version: 0.19.18213 (Git)
Hash: 22babc09954ac6fda9135ee71d68550921659b1c
Python version: 3.7.3
Qt version: 5.12.1
Locale: French/Switzerland (fr_CH)
But now every line, including the axes turn black after selection :
Qt version: 5.12.1
Find your user.cfg and system.cfg files : Macro_findConfigFiles
Imperial system makes no sense, go metric ! ! !
I don't know if a universal fix is possible.
As said above the problem is a combination of the multi-samples and the internal texture format for the framebuffer. So one way to avoid this problem is by decreasing the multi-samples and now with git commit f4bc889b4 it's also possible to change the internal texture format.
Until now the hard-coded value was GL_RGB32F_ARB but it apparently caused problems on older systems. The value GL_RGB32F_ARB once was used because this was (on my old system) the only value where creating an image worked correctly if the model has semi-transparent surfaces. For a model without transparencies the default value works, too.
With the change the default value is not overridden any more and it's the same value used for the real rendering of a QOpenGLWidget. So, I hope that the rubber band selection and saving images works on older systems, too.
If people want/need to override this value then they should open the parameter editor and go to: BaseApp > Preferences > View and create a string of the name InternalTextureFormat. The value should be one of these: Default, GL_RGB, GL_RGBA, GL_RGB8, GL_RGBA8, GL_RGB10, GL_RGB10_A2, GL_RGB16, GL_RGBA16, GL_RGB32F or GL_RGBA32F.
Thanks for the good news - and of course for the work. I hope that the save image will work here again.
And it does fix the issue. After more than 2 years I can create images again! Thank you very much!
