0.19 Daily Build update fail
alberich
Post by alberich » Fri Oct 04, 2019 4:32 pm
When attempting to update my 0.19 daily on
OS: Linux Mint 19.1 (MATE/mate)
Version: 0.19.
Python version: 3.6.8
Qt version: 5.9.5
I get a failure with this message
E: /tmp/apt-dpkg-install-ogJ3dW/1-freecad-daily-runtime_0.19~pre1~201910032155~ubuntu18.04.1_all.deb: trying to overwrite '/usr/share/freecad-daily/Mod/Arch/Presets/ifc_products_IFC2X3.json', which is also in package freecad-daily-common 0.19~pre1~201910032155~ubuntu18.04.1
Seems like a packaging problem.
vocx
Re: 0.19 Daily Build update fail
Post by vocx » Sat Oct 05, 2019 5:21 am
vocx wrote:
Sat Oct 05, 2019 4:11 am
Yes, the main packager is looking into this at the moment. The daily package has been broken for about a month. So hold tight, in the following days and weeks you should expect to see more daily updates, maybe with errors still. If you really need to use the latest code, probably the AppImage or self compilation (CompileOnUnix) is a better option at the moment.
old TempoVis.py in recent builds
kkremitzki wrote:
Fri Oct 04, 2019 10:02 pm
I removed those because, in my testing trying to fix the builds, I was getting errors about them not being present. There's a bug somewhere screwing with all this.
kkremitzki wrote:
Sat Oct 05, 2019 12:27 am
That was the idea with the distinction between freecad-runtime and freecad-common files, with freecad-runtime being meant to solely have Python files. But there's no need for that, in retrospect, so eventually I'll combine the two and just have freecad-common, I think. With 0.19 there will be a break in the binary packages, i.e. libfreecad-python3-0.18 will have its name changed, so that would be a good time to do it.
alberich
Post by alberich » Sat Oct 05, 2019 10:40 am
Gracias por la info. I'll just wait it out.
pl7i92LCNC
Post by pl7i92LCNC » Sat Oct 05, 2019 6:33 pm
i got over this as i used the Appimage as long as this mess is up
THANKS to all that try to fix this
alberich
Post by alberich » Sun Oct 06, 2019 12:58 pm
Yes. That's also what I decided to do. I removed freecad-daily so the update notices for the defective package would stop, then I installed the latest 0.19 appimage. All is well now.
