Easier / Better Way to Do Fillets?
I know to do fillets last and I have been doing that. But changing certain things in a sketch four million steps back quite often breaks the fillets and I have do delete those and redo them. That's not a big deal if your are filleting four lines, but when you have multiple multiple segments to do, that adds up to a real pain. Is there a more efficient way to do fillets in such a way that modifying a sketch won't break them?
Re: Easier / Better Way to Do Fillets?
You are probably experiencing the topological naming problem.
In general, fillets, chamfers, and operations like that, that only refine your shape, should be added at the end of the PartDesign Body. It's like giving a polish. You don't polish a raw metal before cutting it. First you cut your shape, and at the very end, you polish it to give it the final appearance.
In the case of fillets. It's also recommended to integrate the fillet in the sketch, if applicable. That is, drawing the rounded corner in the sketch itself is better than using PartDesign Fillet.
vocx wrote: ↑Sun Oct 06, 2019 12:08 amYou are probably experiencing the topological naming problem.
Yep. That would be the problem. I have done the filleting in the sketches on occasion, but I found that that made designing the finished model more complicated. I may have to try that again on my next go round. Thanks!
On occasion no. It is the recommended way.
Without really knowing what you are modelling it's hard to tell why it would be complicated. it shouldn't be. See feature editing. As long as you use supporting datum objects, like planes and lines, it's usually easy to draw real objects that use those as reference.but I found that that made designing the finished model more complicated...
This was the best way up to version 0.16, and it still is if you sort of follow the manufacturing process. However if you follow the advice for creating stable models, placing fillets and chamfers as soon as possible may minimize the topological naming issues.vocx wrote: ↑Sun Oct 06, 2019 12:08 am In general, fillets, chamfers, and operations like that, that only refine your shape, should be added at the end of the PartDesign Body.
Meh. I really depends on if the fillet is part of the sketch or not. If they are, which is recommended, then they are treated as part of the pad, and hence, more stable.chrisb wrote: ↑Mon Oct 07, 2019 12:52 am This was the best way up to version 0.16, and it still is if you sort of follow the manufacturing process. However if you follow the advice for creating stable models, placing fillets and chamfers as soon as possible may minimize the topological naming issues.
If you look at the quote, you can see that my post was meant to be an addition to your recommendation to place the fillets as late as possible, which is sort of opposite of placing them in the sketch. Of course it is more stable to have them in the sketch, but that's not always possible. And in those cases it helps placing fillets soon.
Yes, of course, the point is, if they are part of the sketch, then they aren't "fillets", they are just part of the sketch, which is recommended. Or said in another way, it's best to avoid adding fillets (explicit fillets).chrisb wrote: ↑Mon Oct 07, 2019 1:10 am If you look at the quote, you can see that my post was meant to be an addition to your recommendation to place the fillets as late as possible, which is sort of opposite of placing them in the sketch. Of course it is more stable to have them in the sketch, but that's not always possible. And in those cases it helps placing fillets soon.
I always appreciate your guy's help and advice, so I really don't want to make anyone mad here, but just because something is the "recommended" way to do something, doesn't mean that that is always the end all be all way to do it. The old saying goes "there is more than one way to skin a cat." I don't know why any one would ever want to skin a cat, but ... there it is.
I am willing to learn new things - that's why I ask questions - but just because something is recommended, doesn't necessarily make it the only way to go about a task.
This is the model I was working on - www.RobotsAndComputers.com/temp/TTS.FCStd - I can't attach it here, it's too large. I did redo the rounded edges on the sketches, but there times when it is impossible (at least to me) to do a fillet in a sketch. The fillets I did here, I don't see any way that those can be done any other way.
I've said this before, but I apologize for my delays in replying. I never get email notifying me of a reply, even though my settings should allow that, so if I don't come here I never see it.
From the Fillet side the model looks rather good, I only would have compiled all 1mm fillets in one operation.
If you are interested in more comments, here they are:
I would recommend to do more in PartDesign workbench
- create the helix in part and use a ShapeBinder in the body
- instead of creating the sweep in Part and cut it, you use a subtractive sweep in PartDesign
- You can even transform the Logo path into a sketch and use that directly in PartDesign for a pocket. Besides, this suggests that the logo may be vastly simplified.
