Greetings everybody
I draw two hexagons. I connect them with edges, then I create faces and finally a shell. All using shapebuilder in Part Workbench. There's a bowl shape. Check geometry tool does not report any problem.
When I try to add a wall thickness with 3D Offset, I get an error message BRepFill_CompatibleWire:SameNumberByPolarMethods : the wires must be closed.
Please, advice me, what I'm doing wrong. Thank.
Version: 0.18.16131 (Git)
Branch: releases/FreeCAD-0-18
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.6
Qt version: 5.6.2
Locale: Czech/CzechRepublic (cs_CZ)
[Solved] 3D Offset tool problems
Re: 3D Offset tool problems
Hard to say without the FreeCAD file. Please upload.
Thanks. Here it is.
- AAA.FCStd
- (79.42 KiB) Downloaded 25 times
The only thing I can do is to confirm the issue even with a simplified version:
CheckGeometry says it is 1 Shell and when I try with a similar shell made from a single not closed sketch it works well:
First select all faces. then click menu Part -> join -> connect objects. Then apply offset. It will generate open 3d offset, not possible for filled shape.
Edit :
[reason for not a good filled shape, but i am not sure]
All faces normal should be pointing outward. but Some faces normal are towards inside. so some faces offset to inside.
Edit :
Thank you both.
The error message states "the wires must be closed".
Maybe you'll know which wires and how to close them...
Additions:
When I use another procedure to create the same shape - using loft, everything works correctly.
However, the procedure used in the first case is more generally applicable and is the recommended workflow in the documentation.
- BBB.FCStd
- (126.7 KiB) Downloaded 10 times
Creation of top face is to difficult for PartWB:3D-Offset.
If you prefer building up from edges to faces to solid, top face has to build up same way.
3D-Offset is used to create outer shell (Fill Offset unchecked)
I used LatticeWB:Sublink to get access to vertexes and edges.
Fill offset doesn't works. I made a forward offset, then a filled backward, it's works.
- GG.FCStd
- (199.21 KiB) Downloaded 29 times
- Capture.PNG (58.81 KiB) Viewed 1565 times
Thank you all.
I appreciate your willingness and your time.
