OS: macOS Mojave (10.14)
Version: 0.19.19541 (Git)
Hash: a797a4172709b82c6cd08dcf6df86cb789aaa3ce
Python version: 3.8.1
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
I often have multiple files open in FreeCAD, and I use different WB for each (for instance, one with FEM WB, one with Part Design WB, one with A2plus or another Assembly WB).
When I switch from file to file, I'd like the toolbar to "remember" what WB was open with that file. i.e. that when I'm on my Assembly file and I go to my file with Part Design, the toolbar changes automatically from the Assembly toolbar to Part Design toolbar. For now, I'm forced to click on the drop down menu to choose the WB again and again.
How to do that ? Is it possible ?
Thanks
How to make the file tab to remember the WB used
Find your user.cfg and system.cfg files : Macro_findConfigFiles
Imperial system makes no sense, go metric ! ! !
Re: How to make the file tab to remember the WB used
I don't think this is possible at the moment, at least not without some Python programming. But it sounds like a reasonable extension. As my workflow is different, I would like to see it configurable.
- dcapeletti
It would also be desirable that when you save and close the file, you save which workbench was used last. That way, when you open the file, you can load that workbench, but if the workbench is not installed, it will show an alert. That's just an idea I had.
- dcapeletti
You could write a macro that observes the changes between document tabs and for each document, create a tuple of the last used bank. When the document is changed, the macro calls the last bank used in that document.
I have no idea how to detect changes between different document tabs.
Given that FC already handles tabs, that seems overkill no ?
And will that be compatible with the necessity of the assembly WBs to have the external part file to be open to insert it /update the part in the assembly file ?
Attached a macro that tries to solve the problem.
Features are :
- Stores for each MDI window what is the active workbench (and of course recall it when the window has been left then reentered)
- Stores the current workbench as own one for all opened windows when launching the macro (of course can be changed afterward)
- Stores the current workbench as own one for newly created window (of course can be changed afterward)
If this is of interest, next steps could be (not exclusive) :
- Make the macro available through addon manager
- Provide the macro as a package so that it can be run at automatically at startup / Make this package available through the addon manager
- Hardcode this behavior in FreeCAD "core" and add an option to enable it
Macro file deleted => can be found on dedicated thread
Thanks, it seems to work .
I will open a feature request with a link to here.
Oops, I just did it...
But, I think your macro deserves to be integrated, not just be a macro lost in the macro pool.
