Hi, I have downloaded this BIM project https://github.com/bitacovir/Farnsworth-House-3D (file https://github.com/bitacovir/Farnsworth ... dows.FCStd ) which I want to publish later on BIMServer for various tests.
I have downloaded and installed BIMServer, which is already running on my local machine.
The problem I have is that when I want to export the model from FreeCAD to BIMServer, there is no root object that can be selected.
Maybe the model is not correctly designed. Could you help me? I have attached images of the problem. Thanks
Edit:
I have also tried to download this project https://github.com/bitacovir/Maison_Dom-Ino_3D and it also presents the same problem, I can't select the root object.
OS: Debian GNU/Linux 9 (stretch) (GNOME/default)
Version: 0.19.20639 (Git) AppImage
Hash: 45aef7b028a54c5420db49ff3284fc7377475e90
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Spanish/Argentina (es_AR)
[Solved]Publish BIM model to BIMServer
- dcapeletti
- BimServer.png (61.8 KiB) Viewed 482 times
- Objeto Raiz.png (84.46 KiB) Viewed 482 times
- dcapeletti
Re: Publish BIM model to BIMServer
Attached is the file I just downloaded and modified.
What I did was add a building object and move everything inside it, which I then wrapped with an arch site. Now when I want to export to bim server you can select Site in the root object, but when I upload it the deserialisers check process is left and the project is never uploaded. Attached image.
- Bim Server.png (64.7 KiB) Viewed 465 times
- Dom-Ino HouseV3.FCStd
- (819.19 KiB) Downloaded 30 times
- dcapeletti
Please move this thread to Bim's forum. Thanks
- dcapeletti
