I'm having issues with the model 'jumping' when I'm using my SpaceMouse to orbit and pan. These operations work fine when using the mouse, but it's almost like watching terrible stop motion when using the SpaceMouse for the same operations.
I've already confirmed that everything is properly unchecked in the 3DConnexxion driver so that double events aren't being sent per the Wiki, and that has helped significantly, but it is still unusable. I also confirmed that the 3D mouse settings are all at default under Customization.
I'm going to try and spin up a Linux VM and try it there to see if I experience a difference, but was hoping maybe there is something simple that I'm missing to get things working smooth.
Here's the output of my About::FreeCAD
OS: Windows 10 (10.0)
Version: 0.19.21911 +2545 (Git)
Branch: LinkStage3
Hash: 04c80c99eee0f7d2f761bdc7d8b32c077adefdec
Python version: 3.6.8
Qt version: 5.12.1
Not being a QT developer I did also take a look at the code for how the SpaceMouse is handled on Windows, and I don't see anything that smacks me in the face here. Just looks like the raw events are passed through the user filters then handed off to Move3D, so the only other possible thing I could see it being is some polling/timing issue...
Any help is appreciated!
Choppy movements when using SpaceMouse on Windows
Re: Choppy movements when using SpaceMouse on Windows
So interestingly, I spun up a VM (Ubuntu Latest) and installed FreeCad 0.19 from snap. Once I fixed an apparmor issue (Needed to add access to /run/spcnav.sock) everything works great and I get phenominally clean resolution when orbiting/etc. This leads me to believe that it possibly is an issue with how FreeCAD and QT are interacting with the SpaceNavigator events.
If you are using realthunder's branch, you must contact him, as he has made several changes to his code, so the general public that is using the main version may not be aware of these issues.
This is a really good point, I'll reinstall with 0.19 (not realthunder's branch) and see if the results are the same.
It did push me to take stock of all my apps and found that with the exception of ONE (I'm looking at you Cricut Design Center) all of them have native Linux support, so may just switch this machine to Ubuntu permanently and run Windows in a VM.
