[FreeCAD 0.19.22411, Win10] Access Violation when trying to create a fillet
Hi there
New FreeCAD user here, currently running through various CAD challenges to get up to speed. Seeing a highly annoying Access Violation here and there that seems to be connected with fillets and that renders the UI unusable and requires a restart of FreeCAD to get back in business.
File with which to reproduce and log are attached. I can reproduce this reliably by trying to add any fillet to the area indicated in the attached screenshot on the "Phase 2" body:
I am aware that this is probably caused by me still doing something wrong in my modelling, but as it causes the UI to do nothing but log endless Access Violation lines to the report console ("17:22:41 Unhandled Base::Exception caught in GUIApplication::notify. The error message is: Access violation") I figured I should still report it. Happy to answer any questions or collect more data.
OS: Windows 10 (10.0)
Version: 0.19.22411 (Git)
Hash: d4519d5aec15bc08f029da5ed15410a494b57b2c
Python version: 3.8.5
Qt version: 5.12.6
Coin version: 4.0.0
OCC version: 7.4.0
Qt version: 5.12.6
Coin version: 4.0.0
OCC version: 7.4.0
- Model Mania 2020.FCStd
- (683.41 KiB) Downloaded 38 times
- FreeCAD-accessviolation.log
- (32.08 KiB) Downloaded 62 times
Re: [FreeCAD 0.19.22411, Win10] Access Violation when trying to create a fillet
Freecad still tricky with fillets.
Need to looking for a lot of combinations to find the good solution for their good order.
I've move the sketch005 to avoid a edge.
here file link: https://mon-partage.fr/f/l4WgIe8n/
- Capture.JPG (54.28 KiB) Viewed 1761 times
I see no error messages in my system, but indeed if you try to create a fillet it's not possible. Whenever you have issues, use Part_CheckGeometry to check the validity of your shapes. You can test each feature one by one until you find the problem. A problem is the edges that are created in the solid when you perform the groove. These types of coplanar faces or colinear edges often cause problems with further boolean operations (blame OpenCASCADE). You can choose the groove and refine it with the option in the property editor. Then the solid is no longer invalid and you can proceed with more dressup features.
OS: Ubuntu 18.04.5 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.22465 (Git)
Build type: Debug
Hash: a028ea94ccdc0c024c73e6d583fcf11b2c039d46
Python version: 3.6.9
Qt version: 5.9.5
Thank you! I figured it has something to do with that as I've had problems with that in other CAD packages as well. Will take a look at all those links and recommendations, highly appreciated!
Still not ideal to have to restart to get the tool back in usable shape. While that Access Violation gets logged endlessly I can do pretty much nothing but save and exit. Getting an error message as in other cases with invalid geometry would certainly be more helpful here, even it's just "oops something went wrong here". In short, a more graceful handling of some error condition night be needed here. Will try to spin up a linux vm tomorrow and test a nightly as it's apparently not generally reproducing.
We have a real open source and 3D-printing celebrity here! Thank you, foosel, for creating OctoPrint. I use it regularly.
I'm also attaching my file, perhaps someone can see whether there is anything wrong with it that I missed. To be clear it is the fillets inside the pockets that don't want to play along. There is no issue with the top outer edge.
I just tried making the same model from the Model Mania collection in up-to-date FreeCAD 0.19 on (X)ubuntu 18.04 and while it doesn't crash, it does give the rather terse messages of "Failed to create fillet" and "Resulting shape is invalid" a lot. It will fillet some of the edges but when I try to add some more it will inevitably fail at some point. This is with a refined solid, frequent recomputes of the entire model, and seemingly valid shape according to "Check geometry". The order in which you select the edges for filleting seems to matter but I can't figure it out. I'm very curious how GlouGlou (above) did it!
OS: Ubuntu 18.04.5 LTS (XFCE/xubuntu)
Version: 0.19.22474 (Git) AppImage
Hash: a44f8ffd427fa9b23b1f00dbf62d66cd152cd774
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.4.0
- 2020-phase2.FCStd
- (510.49 KiB) Downloaded 31 times
There was a challenge concerning this model in the german forum. If you cannot find it, I could give it a try.
Happy to report that the Access Violation no longer reproduces under
and also not under in a Linux VM with
Awesome!
Fillet obviously still fails, which is fine, my geometry needs some work. As long as the app stays usable such mistakes aren't as frustrating to learn from
Qt version: 5.12.6
Coin version: 4.0.0
OCC version: 7.4.0
OS: Ubuntu 20.04.1 LTS (ubuntu:GNOME/ubuntu)
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.4.0
Hi, glad to hear it's helping you
Will try to dig it up, thank you!
I have the same problem with fillets, I am new to FC (former solidworks and F360 user). The problem is that fillet bugs cannot be reproduced, sometimes the fillet works and sometimes it doesn't. Maybe it is something to do with the order I select edges ? any tips or workaround to make fillets work better?
I was testing the Model-Mania 2018 when the issue occurred. The program spams the message:
until it crashes.
My about info:
My about info:
Qt version: 5.12.6
Coin version: 4.0.0
OCC version: 7.4.0
- test-fc.png (255.34 KiB) Viewed 1607 times
This object doesn't look too critical in terms of filleting. If fillets fail, retry with a very small radius, such as 0.01 and increase it until it fails. Look at the state just before: Are there any edges converging? Fillets cannot consume more then the adjacent faces and they often fail if vertices are involved, where more than 3 edges meet. Another cause of failure are very small or near to but not quite tangent edges.
For further detailed help you should give us more information:
- Upload the file
- tell us in detail where you failed to fillet with which parameters
- Upload the file
Try updating to 0.19.22474. It didn't fix my fillet troubles, but I no longer get the endless stream of Access Violation errors and non functional UI I did with 0.19.22411farahats9 wrote: ↑Tue Sep 22, 2020 12:33 am My about info:Code: Select all
OS: Windows 10 (10.0) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22411 (Git) Build type: Release Branch: master Hash: d4519d5aec15bc08f029da5ed15410a494b57b2c Python version: 3.8.5 Qt version: 5.12.6 Coin version: 4.0.0 OCC version: 7.4.0 Locale: English/United States (en_US)
