[solved] select a shape
herrdeh
Post by herrdeh » Wed Sep 03, 2014 12:22 pm
Hi to everybody,
I'm a very beginner with FreeCAD. Tried to rotate or extrude boxes or cylinders, selected the item by clicking once, colour changed to greenish, then selected "rotate" and typed in something like 90 dgrs.
I ever get the message "Select a shape for revolution (extrusion, etc. ...), first".
How does FreeCAD want me to select the item to work on?
Thanks a lot in advance,
Wolf
Re: select a shape
Post by yorik » Wed Sep 03, 2014 1:06 pm
It's always useful to post your system info as asked on the "IMPORTANT: Please read first before asking for help" topic on top of this forum...
But I would say for some reason your objects were not selected (maybe you deselected them, I can't say). Make sure they are highlighted in the tree view when you press the rotate button. In any case, as the command tells you, you can also pick an object after you pressed the button.
quick61
Re: select a shape
Post by quick61 » Wed Sep 03, 2014 2:02 pm
herrdeh wrote:Hi to everybody,
Wolf
Hi Wolf, welcome to FreeCAD and the forum.
When you say rotate, are you wanting to rotate the orientation of the part or are you wanting to revolve a shape around an axis (like a lathe extrude)? If you are wanting to rotate the parts orientation, you need to use Edit > Placement. There you will get a dialog in your combo view that will allow you to do this. If you are wanting to rotate a shape (create a lathed part from a shape profile) then you need to use a 2D shape to perform that function. You can not Revolve 3D parts. Posting a file along with your FreeCAD info would be of help too.
Mark
bejant
Re: select a shape
Post by bejant » Wed Sep 03, 2014 4:41 pm
yorik wrote:It's always useful to post your system info as asked on the "IMPORTANT: Please read first before asking for help" topic on top of this forum
quick61 wrote:Posting a file along with your FreeCAD info would be of help too.
Hi Wolf, if you do this we can better help get you started.
herrdeh
Re: select a shape
Post by herrdeh » Wed Sep 03, 2014 4:59 pm
Hello everybody,
thanks a lot for the quick reply. Mark's pointing me to "placement" looks like the right thing to to.
Thanks a lot
Wolf
