FreeCAD Logo Design
marcuspollio
Re: FreeCAD Logo Design
Post by marcuspollio »
Hi there !
Here another version, inspired by the one of
octoshock wrote: Thu Aug 02, 2018 3:28 am
The font used is "sans-serif" bold from the GNU FreeFont
fc.svg
(7.85 KiB) Downloaded 119 times
I like this one much more than that of tuqueque, because the F doesn't look so brutally chomped (and not only because it was posted in a separate thread :lol: ).
However, the C looks a tiny little bit too fat, although it probably is the same as the F. Perhaps it's the teeth making it look so.
apeltauer
Post by apeltauer »
marcuspollio wrote: Wed Aug 19, 2020 1:43 pm Hi there !
Here another version, inspired by the one of....
:+1:
Now if it gets a little bit 3d(ish) this would make it even better.... :)
vocx
Post by vocx »
chrisb wrote: Wed Aug 19, 2020 11:29 pm ...
This logo is a perfect replacement in my opinion, I would not be against doing the change immediately. Fat C looks great.
Not knowing the correct notions for fonts in english, let me use FreeCAD's sketcher to express what I would like to see: Could you provide a version where the two selected lines have the same length:
Snip macro screenshot-97fb07.png (42.72 KiB) Viewed 2388 times
vanuan
Post by vanuan »
chrisb wrote: Thu Aug 20, 2020 5:54 pm Not knowing the correct notions for fonts in english, let me use FreeCAD's sketcher to express what I would like to see: Could you provide a version where the two selected lines have the same length:
Like this?
fc.svg
(6.86 KiB) Downloaded 70 times
Thanks, looks better to me. I have the feeling that someone with much experience in typography could make this perfect.
mikeprice99
Post by mikeprice99 »
I'm not a graphic design professional, but AFAIK most fonts look better when rounded letters dip a little below the level of other letters and reach above them, so I've done a version slightly enlarging the cog:
I've also done a thorough clean up of the svg file.
fc.svg
(2.94 KiB) Downloaded 71 times
Looks good to me.
Asim
Post by Asim »
Thought I might put this one up from another thread I posted some time ago: https://forum.freecadweb.org/viewtopic.php?f=34&t=48972
All work done as vectors.
