[ Solved ] Quickly switch background color
Hi
Does exist a way to switch the 3D view background color without opening user preference panel?
I ask this because I use a white background for screenshot and the blue gradients one for modeling.
Thanks!
Thanks!
- microelly2
Re: Quickly switch background color
you can write your macro
just look, what are the roght color value for your case
rGrp=FreeCAD.ParamGet('User parameter:BaseApp/Preferences/View')
atr="HeadlightIntensity"
rGrp.SetInt(atr,100)
atr="BackgroundColor"
rGrp.SetUnsigned(atr,1437270015)
I recently worked on the wiki and would have appreciated such a whitening function.
Thank you !
Solved with :
I manually set the simple color as white in user pref.
Solved with :
attr = 'Gradient'
curval = rGrp.GetBool(attr)
rGrp.SetBool(attr, not curval)
Gui.activeView().redraw()
Re: [ Solved ] Quickly switch background color
Could not get microelly2's code working. flachyjoe's works.
OS: Mac OS X
Version: 0.18.13976 (Git)
Branch: (HEAD detached at fae0de5)
Hash: fae0de58581694157a97d567c151bdce75d387dc
Python version: 2.7.15
Qt version: 5.11.0
OCC version: 7.2.0
OS: Mac OS X
Qt version: 5.11.0
OCC version: 7.2.0
The built-in save picture doesn't work on some Macs since mid 0.17 times. That's not really an issue for me, because the standard screenshot tool serves the purpose very well; I can select the rectangle to be shot making the screenshots smaller and usually more focused on the matter.
Message is:
Message is:
<unknown exception traceback><type 'exceptions.RuntimeError'>: Cannot save null image.
You're right but as the settings are not saved between Save Picture calls, it's not as quick as a macro button in toolbar.
