Glass
Re: Glass
Post by Kunda1 »
opossumax wrote: Wed Sep 23, 2020 5:16 pm I am having an issue with the tree autohiding unless I put the mouse directly over it. Also, the tree is very short and I have to scroll through it.
I installed Glass through the addon manager.
I would attach an image but I don't have time right now to jump through those hoops.
Thanks for the heads up. @triplus hasn't been active lately on the forum. Not sure if @triplus is actively developing Glass ATM.
There is another overlay mode being worked on by Realthunder..but there are hoops to jump through to use it.
https://forum.freecadweb.org/viewtopic.php?f=34&t=45349
asker
Re: Glass
Post by asker »
Instead of the combo-view tree-view appears when I pres Q+1.
Is there a way to change this behavior please?
greetings
Asker
farahats9
Re: Glass
Post by farahats9 »
I just made a pull request fixing the issue of text transparency when renaming a node. I hope triplus would merge it.
https://github.com/triplus/Glass/pull/6
Re: Glass
Post by Kunda1 »
farahats9 wrote: Sat Jan 23, 2021 2:02 am I just made a pull request fixing the issue of text transparency when renaming a node. I hope triplus would merge it.
@triplus has been 'off the radar' for a while now. I'll talk to yorik and we'll clone his repos so issues can be addressed
drucken
Re: Glass
Post by drucken »
Is there a setting/tweak to hide the Tree from Combo view by default (what he is doing with the mouse for about 2 seconds here https://youtu.be/ny31diN1ZhM?t=519)?
In combination with Glass the Combo view Tree seems to be an unnecessary duplicate...?
adrianinsaval
Re: Glass
Post by adrianinsaval »
I did that in my fork, it has other differences too though
https://github.com/adrianinsaval/Glass/ ... ssTreeView
Re: Glass
Post by Kunda1 »
I'm thinking of redirecting Glass (in the Addon Manager) from @triplus's to your repo @adrianinsaval
Is that OK with you?
edit: since @triplus has been AWOL
drucken
Re: Glass
Post by drucken »
adrianinsaval wrote: Thu Mar 25, 2021 3:14 pm I did that in my fork, it has other differences too though
Thank you! I am looking into it, although I'm not really sure what I am doing - trial and erroring myself forward :roll:
Do you think it is technically possible to make the Glass Tree area adopt to the size of the tree? That would be nice, since the transparent background behind the tree is still blocking the pointer's editing and zooming/rotating possibilities in that area of the 3D view...
(So if the tree would contain 5 rows, then the glass tree area should adopt to that height, and not go all the way down to the bottom of the 3D view...)
Or maybe even better - to make the tree background area not only transparent, but completely hidden/gone/disabled?
Greetings!
adrianinsaval
Re: Glass
I don't have enough knowledge to do something like that but thankfully realthunder has it and has done it, it's still only in his fork of FreeCAD but should be eventually integrated into FreeCAD, being an UI only feature that doesn't break old files or workflows I don't think it will be met with as much resistance (and therefore delays) as his other developments so I am hopeful. There really isn't much to gain by continuing to develop this addon considering a better method is already further in develoment.
drucken
Re: Glass
Post by drucken »
adrianinsaval wrote: Fri Mar 26, 2021 4:57 pm I don't have enough knowledge to do something like that but thankfully realthunder has it and has done it, it's still only in his fork of FreeCAD but should be eventually integrated into FreeCAD, being an UI only feature that doesn't break old files or workflows I don't think it will be met with as much resistance (and therefore delays) as his other developments so I am hopeful. There really isn't much to gain by continuing to develop this addon considering a better method is already further in develoment.
Aha, I wasn't aware of that... So what realthunder developed is a replacement of Glass, build into FreeCAD without the need for an addon?
