Window focus problem
Moderator: agryson
OficineRobotica
Post by OficineRobotica » Mon Sep 23, 2019 9:34 pm
Hello to all.
I have this strange problem with freecad 0.19 appimage on kubuntu 19.10. It seems that the main program window loses focus in some circumstances. By this i mean that , for example and only at times I loose the global menu in the top bar.
But , most annoyingly it is the fact that pop up windows of freecad don't "pop up" but under the main window and to have them i need to ALT-TAB freecad with some other application to have them apear.
In this example i choosed a constraint and pushed the edit constrain icon but the pop up window does not apear. It will after i change focus with some other application.
Note that freecad from the daily ppa doesn't suffer from this problem
I use the ClearMenuBar parameter as sugested by triplus here https://forum.freecadweb.org/viewtopic. ... 66#p290053 but i dont think that is the problem.
Anybody has any suggestion?
OS: Ubuntu Eoan Ermine (development branch) (KDE/plasma)
Version: 0.19.18260 (Git) AppImage
Hash: dbf0644b60c35273525985fa13859ad39b0c10df
Python version: 3.7.3
Qt version: 5.12.1
Locale: Italian/Italy (it_IT)
openBrain
Re: Window focus problem
Post by openBrain » Tue Sep 24, 2019 9:00 am
This is something very strange that your global menu items seem to appear into the Kbar... Is it something native in Kubuntu 19.10? Could it be removed to have a "standard" behavior?
OficineRobotica
Post by OficineRobotica » Tue Sep 24, 2019 9:28 am
The global menu is an option and i'm a long time user but freecad never presented this kind of behavior before 0.19.18260 (Git) AppImage . I disabled the global menu to see if it can be the cause but unfortunately freecad still does "hide" pop up windows.
In the screenshot i chose a constraint and pushed the button to edit it. A pop up window should apear but it doesn't
This behavior is extended to all pop up windows. If i right click an item in the tree and chose Appearance , for example, i need to alt-tab back and forth to get the Appearance window to show. Also the behavior is not consistent , meaning that , at times , changing the workbench might change the weird state that the main window is in and make popup windows magically re appear. The daily ppa version of freecad behaves absolutely normal tough. It's the appimage one that has problems and i prefer the appimage.
OficineRobotica
Post by OficineRobotica » Tue Sep 24, 2019 9:42 am
Also, doing some further digging it seems that this problem is present only on kubuntu 19.10. Triyng the same appimage on kde neon, based on ubuntu 18.04 i don't seem to have the same problem
In this case, freecad info
OS: KDE neon User Edition 5.16 (KDE//usr/share/xsessions/plasma)
Qt version: 5.12.1
looo
Post by looo » Tue Sep 24, 2019 9:52 am
Which version of qt does the daily ppa use?
This might be related to the update to qt5.12. There is a new version of qt5.12 coming soon to the appimage. Not sure if this will fix your issue but I guess it's worth waiting for it before diving into this problem. I will trigger a build today so appimage will be updated tomorrow.
I also cannot reproduce with ubuntu 18.04.
OficineRobotica
Post by OficineRobotica » Tue Sep 24, 2019 9:57 am
Freecad daily ppa info
Version: 0.19.
Qt version: 5.12.2
OficineRobotica
Post by OficineRobotica » Tue Sep 24, 2019 10:02 am
Thank you...i will try it as soon as it's out.
OficineRobotica
Post by OficineRobotica » Wed Sep 25, 2019 4:44 am
I tried the latest appimage but unfortunately the problem still persists.
Version: 0.19.18289 (Git) AppImage
Hash: bd6da5699ee63a0d568c940328cdb82cbfaac94a
Qt version: 5.12.5
