Who wants to contribute the pyflow integration project.
There is a art work task: create icons for the nodes into the pink frame
the grasshopper symbols are here
http://rhino.github.io/
Mod Edit: original thread at https://forum.freecadweb.org/viewtopic.php?f=8&t=36299
node editor/pyflow icons needed
- microelly2
Reason: Split from https://forum.freecadweb.org/viewtopic.php?f=8&t=36299
Re: node editor/pyflow icons needed
Ticket is at: https://github.com/microelly2/NodeEditor/issues/7
To all readers. If you want to contribute icons, please take a moment to read Artwork Guidelines.
The images there are SVGs so you can download one of them and start creating the icons.
vocx wrote: To all readers. If you want to contribute icons, please take a moment to read Artwork Guidelines.
What do you want exactly?microelly2 wrote: ↑Wed Dec 04, 2019 4:15 pm the grasshopper symbols are here
To replicate all grasshopper symbols? There are hundreds...
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
- microelly2
We can reuse the known icons from FreeCAD core and moduls
but there are other methods too.
Whenever a new node is created the question is - adapt the grasshopper icon or create a completly new My idea wa to connect icons by name convention
for "new" nodes we need new symbols.
For example I would use a lighthouse for the blinker and a satellite dish for the receiver
- microelly2
first trymicroelly2 wrote: ↑Sun Dec 08, 2019 12:58 pm For example I would use a lighthouse for the blinker and a satellite dish for the receiver
microelly2 wrote: ↑Sun Dec 08, 2019 6:38 pmOk. If you decide to use the FreeCAD icons you can reuse the existing ones. Then, I could help with some of the new icons for new nodes that you create. But you must indicate the node names and concept. Like you did here: Blinker node, Reciever node.microelly2 wrote: ↑Sun Dec 08, 2019 12:58 pm For example I would use a lighthouse for the blinker and a satellite dish for the receiver
I used green color because it related to data and linking in other icons.
::bitacovir::
bitacovir wrote:
Thanks for stepping up this and previous times for creating requested icons.
- microelly2
Wow, Thank you! The list of nodes is here: http://freecadbuch.de/doku.php?id=nodes#fc_box
if the node is documented with fc_box the image name should be freecad_box.svg
your icons are now freecad_blinker.svg and freecad_receiver.svg
