Unwanted Value Changes in Custom Widgets
wandererfan
Post by wandererfan »
When I use the mouse wheel to scroll, any of the FC custom widgets that are touched by the cursor in passing increment or decrement their value. Don't think I've ever run into this in other applications.
Does anybody else notice this behaviour?
To me, the scroll wheel should only affect a widget's value if that widget already has focus via click or tab.
Thoughts?
Re: Unwanted Value Changes in Custom Widgets
Post by Kunda1 »
wandererfan wrote: Mon Jan 27, 2020 1:55 pm Does anybody else notice this behaviour?
Thoughts?
This is a super common phenomena in Scribus as well which uses Qt.
openBrain
Post by openBrain »
It has pros (you can change a value without having to click on it first) and cons (you sometimes change value inadvertently). :)
I don't know if it's enough, but we could change focus policy of the spin boxes with :
spinbox->setFocusPolicy(Qt::StrongFocus) #Default is Qt::WheelFocus which also accepts focus at wheel event
At least we could test with some Python to see if it works. ;)
I would appreciate the extra click. Working on a notebok I have a) always a small screen and b) often no mouse attached. Thus I frequently have to scroll the DataTab, and if the mouse is not in the left part of the widget then some values may be changed inadvertently.
wandererfan
openBrain wrote: Mon Jan 27, 2020 2:34 pm I don't know if it's enough, but we could change focus policy of the spin boxes with :
I tried this in "InputField.cpp" and it didn't help. What did help was changing the "wheelEvent" handler to not accept events if the input field didn't already have focus.
Have to check the other custom widgets and see if the same tweak works.
wandererfan
chrisb wrote: Mon Jan 27, 2020 9:45 pm I would appreciate the extra click. Working on a notebok I have a) always a small screen and b) often no mouse attached. Thus I frequently have to scroll the DataTab, and if the mouse is not in the left part of the widget then some values may be changed inadvertently.
This is my situation as well.
wandererfan
Here is an illustration of the current situation vs "how it should be". Excuse the video quality.
In the Preset widget you can clearly see values changes during scrolling using the current code. With proposed code the Preset widget is quite resistant to undesired changes.
wandererfan
And here is a little write up of the proposed changes. Not that individual maintainer will have to decide if they want to use the new options or not.
Proposed solution for preventing uncommanded value changes on scroll or
mouse wheel.
Fields treated with the following options require Tab or Click to receive focus,
and will not change values until they have focus. Once they have focus, the mouse
wheel can scroll the values up and down.
The behaviour of fields not treated with these option will be unchanged.
Usage of new options:
C++
#include <Gui/Widgets.h>
    //regular Qt widgets
    //sbScale is a QDoubleSpin box
    ui->sbScale->installEventFilter(new Gui::WheelFilter(ui->sbScale));
    //FC custom widgets
    //ifInput is Gui::InputField
    ui->ifInput->setWheelBlocker(true)
Python
# FreeCADGui.InputField
    inField = ui.createWidget("Gui::InputField")
    inField.setProperty("wheelBlocker", True)
# regular Qt Widgets
    inCombo = QtGui.QComboBox()
    WheelFilter(inCombo)    #*** the WheelFilter class needs a home from which
                            #*** it can be imported or it can just be copy/pasted.
                            #*** It is < 20 lines of code, but it would be best
                            #*** from a maintenance perspective if the code was
                            #*** only in 1 place.
