[Help]Icons for Trails Workbench
Moderator: agryson
bitacovir
Re: [Help]Icons for Trails Workbench
Post by bitacovir » Sat May 30, 2020 1:19 pm
HakanSeven12 wrote:
Sat May 30, 2020 5:53 am
Looks good :) my mesh is not like a box. It represent the earth surface. Here an example
Here, I changed section icon a bit. Also, I see contours does not look clear enough with dark background. So, I made the white lines a bit thicker.
Trail_WB_MeshSections.svg
(11.78 KiB) Downloaded 5 times
Trail_WB_Contours_Icon.svg
(17.56 KiB) Downloaded 7 times
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
HakanSeven12
Post by HakanSeven12 » Sat May 30, 2020 2:04 pm
That looks better ;) Can you do something for "export points to file" icon?(the second icon at the picture)
new icons.png (8.95 KiB) Viewed 326 times
bitacovir
Post by bitacovir » Sat May 30, 2020 2:24 pm
Here you are... Are these point symbols clear enough? Should I change them from blue to a whiter color?
Trail_WB_ExportPointFile.svg
(10.98 KiB) Downloaded 12 times
::bitacovir::
My old Blog
HakanSeven12
Post by HakanSeven12 » Sat May 30, 2020 2:47 pm
Maybe you can make it bigger and remove paper from background and you can use a whiter color
bitacovir
Post by bitacovir » Sat May 30, 2020 3:39 pm
The paper is a global convention for documents and files and it is behind the other icons, so It does not interfere. But I made bigger the point symbol and in yellow color.
Trail_WB_ImportPointFile.svg
(12.29 KiB) Downloaded 7 times
(11.63 KiB) Downloaded 6 times
::bitacovir::
My old Blog
HakanSeven12
Post by HakanSeven12 » Sat May 30, 2020 3:59 pm
Seems fine :)
HakanSeven12
Post by HakanSeven12 » Mon Jun 01, 2020 2:09 pm
I tested them looks nice thanks for help ;)
new icon.png (14.91 KiB) Viewed 200 times
