How would you go about to create a minimalist version of FreeCAD with an own GUI?
So at this moment I am able to create custom macros with GUIs using PySide2 and Qt and integrate them into FreeCAD, but how can I create my own UI using the 3D viewer?
How to create own GUI?
FreeCAD als Maschinenbauer in die Konstruktion und Fertigung integrieren. Schulung buchen: www.alsado.de/freecad-schulungen
Re: How to create own GUI?
If we are talking about the easiest and simplest way, select Complete WB in workbench selector and use:
https://wiki.freecadweb.org/Customize_Toolbars
To define some toolbars. Such approach should result in having a minimalist version of FreeCAD. If you want to go a step further and don't want to have toolbars, try out a module, such as command panel. There you can fit a large number of commands in a rather smallish menu and after to invoke it on demand.
Would removing built in Toolbars and Commands from the Command Bar require QT Designer? I want to remove some of the Std Menus from the Command Bar.
Thank you for your tip. it should do it for now.
- adrianinsaval
