With the same FreeCAD file, user.cfg and system.cfg for both tests, using :
OS: Windows 7
Version: 0.18.14575 (Git)
Hash: a624fee2c27bbbb869df6a8ce40438953a282a8c
Python version: 2.7.14
OCC version: 7.2.0
the dimensions when changed colour were both changed for the text and the arrows but using:
OS: Windows 7
Version: 0.18.15860 (Git)
Hash: 3b708c7f84b0425076b520e1d95627b20fd75fe0
OCC version: 7.2.0
only the arrows change colour. Was this due to a request to comply with a particular standard, is there another setting I need to change in the most recent build or have I stumbled upon a regression?
[Solved] Non-standard coloured dimensions?
- wandererfan
- wandererfan
Re: Non-standard coloured dimensions?
Should be fixed by git commit 21353779d9f
Thanks @wandererfan, sorry for the delay confirming all is sorted, I've only just had chance to test it.
It would appear there's been a regression on the same issue but this time the text is the correct colour and it's the dimension line and arrows that are black. The last correct working build I have is:
OS: Windows 7 SP 1 (6.1)
Version: 0.19.17803 (Git)
Hash: 89961a33d46063a43e9fb5b0308ca95d559eca94
Python version: 3.6.8
Qt version: 5.12.1
from around 20th August.
All builds since including the latest I have, produce a black dimension line/arrows with correctly coloured text:
Version: 0.19.18284 (Git)
Hash: cd8f0e0960d048032b6967edb9e8952541a5eb6c
Qt version: 5.12.1
- wandererfan
Things might be very different after this change.
Sorry to say but while the new functionality looks good the colour bug is still reproducible using:
Version: 0.19.18351 (Git)
Hash: fb7a03a04d04e770305f96a31b608d6951d927c8
Qt version: 5.12.1
- wandererfan
Should be (mostly) fixed by git commit d7dabeb885 and git commit 12335c7d52.
Still an issue where the dimension text changes color while being dragged. The colour is corrected when the cursor leaves the dim text area.
Thanks for the swift fix.
