[ Fixed ] [ Bug ] TechDraw_DraftView does not recognize Draft objects anymore
Roy_043
Post by Roy_043 » Mon May 18, 2020 8:23 pm
It seems that TechDraw_DraftView does not recognize Draft objects anymore. Is this a known issue?
OS: Windows 8.1 (6.3)
Version: 0.19.21097 (Git)
Hash: a5ab09aa0941cc945e59848897b160f8cbfc0831
Python version: 3.6.8
Qt version: 5.12.1
vocx
Re: [ Bug ] TechDraw_DraftView does not recognize Draft objects anymore
Post by vocx » Mon May 18, 2020 11:00 pm
This seems to be the same problem, which was already solved in the master code.
[regression] Draft Dims & Annotation not working with ArchSections + Techdraw
Why do you post here? If you posted in the Draft forum you would get more visibility when it's about Draft problems.
Also, you should always list the steps to reproduce the problem, even if you think they are obvious.
regis
Post by regis » Tue May 19, 2020 12:23 am
Draft forum
show me where this is because I searched for it, but ended up posting in the "DRAFT, Arch & Bim" forum
My bad if i'm contributing to poor organising of posts and bug reporting
Roy_043
Post by Roy_043 » Tue May 19, 2020 7:20 am
No I don't think that is the same issue.
Scenario:
  1. Create a Draft_Rectangle.
  2. Switch to the TechDraw WB.
  3. Create a default page.
  4. Select the rectangle in the tree.
  5. Invoke TechDraw_DraftView.
  6. Result: Alert dialog: "There were no DraftWB objects in the selection".
carlopav
Post by carlopav » Tue May 19, 2020 7:45 am
Definitely it's not the same issue...
Syres
Post by Syres » Tue May 19, 2020 8:55 am
I can help narrow down when the regression was introduced. The last build when it worked as expected was:
OS: Windows 7 SP 1 (6.1)
Version: 0.19.20839 (Git)
Hash: 09005766f10539dfe32314c33c2cd3efe9141d0b
Qt version: 5.12.1
and the first build I have when it stopped working is:
Version: 0.19.20887 (Git)
Hash: 42c56d9fef82b484448e3730eb7da69c48fe1374
Qt version: 5.12.1
So sometime end of April/early May is when the regression was introduced. A quick look of the code in src/Mod/TechDraw/Gui/Command.cpp around line 1089, it would appear (I've not done any debugging) that it doesn't recognise the rectangle as DrawGuiUtil::isDraftObject type, has this changed?
    int draftItemsFound = 0;
    for (std::vector<App::DocumentObject*>::iterator it = objects.begin(); it != objects.end(); ++it) {
        if (DrawGuiUtil::isDraftObject((*it)))  {
            draftItemsFound++;
Edit: Looks like this is the cause, the top Proxy is from build 0.19.20839 and the lower one from 0.19.20887:
Syres
Post by Syres » Tue May 19, 2020 10:07 am
Is it as easy as changing line 168 in src/Mod/Techdraw/Gui/DrawGuiUtil.cpp from:
                        if (ss.str().find("Draft") != std::string::npos) {
to:
                        if (ss.str().find("draftobjects") != std::string::npos) {
or is that bad?
vocx
Post by vocx » Tue May 19, 2020 1:17 pm
wandererfan wrote: ping
It seems this one is on TechDraw.
Roy_043
Post by Roy_043 » Tue May 19, 2020 2:13 pm
So my topic got moved to the wrong forum! :lol:
Post by chrisb » Tue May 19, 2020 3:49 pm
Moved it to where I wanted to move it in the first place.
