Hello, I've been using FreeCad TechDraw, and it works very well. However I'm struggling with one aspect of creating angle measurements. How can I create an angle measurement that simple goes from an angle to a horizontal line if there is no line or facet in the part, or there are not three points to choose from.
I have tried creating a horizontal LeaderLine, however I cannot measure the angle from my part to the leader line. Is there some way to simply draw a horizontal line in TechDraw and measure an angle from my part to the horizontal line? Below is an image of an example:
I want to add an angle measurement from my part to the horizontal where I have drawn a red circle, however I cannot find an easy way to make that happen without modifying the part. Surly there is a way to either add a horizontal line I can use to measure to, or add an arbitrary angle? Any guidance or assistance is greatly appreciated.
OS: macOS 10.15
Version: 0.19.21514 (Git)
Hash: 89ddab33f692a9bd739171689f9ab0eb58d64b35
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
Create angle measurement to horizontal
- wandererfan
Re: Create angle measurement to horizontal
Some useful hints in this post.
A function to create a cosmetic line from the Gui is coming. It is stacked up behind some bug fixes.
Awesome thank you. You mentioned in that thread that you can draw a line using python in TechDraw. Can you link me to an example or resources for carrying that out without having to draw a line in 3d space for now? Either way this is very helpful information.wandererfan wrote: ↑Tue Jul 28, 2020 1:43 pmSome useful hints in this post.
For anyone else coming across this thread, wandererfan's solution mentioned without writing python code is to create a line object from the part menu
Place the line where you want it to be in 3D space and include it inside a compound part, or just capture it in TechDraw by inserting a view with it selected. Now you can draw an angle.
- wandererfan
TechDraw_API near the bottom. You're looking for "makeCosmeticLine". Note that the points are in paper space, not model space. A version that takes 3D points is in the infamous queue.
Thank you so much this is very helpful.
