Was working on getting angle and figured that out. Wanted it on top of View001 but couldn't select the two vertices to add extended cosmetic line.
Determined it was the View Frame. Not a big problem as have two ways around. One is to move View002 out of way and other is in Tree toggle visibility on View002. Like toggle visibility method better as doesn't disturb placement. Question is there a setting to move View Frame position in what I would equate with graphics program move layers? I tend to miss obvious settings sometimes did search for answer with various search parameters and did not find in forums.
Edit forgot info
OS: Ubuntu 20.04.1 LTS (MATE/mate)
Version: 0.19.
Branch: unknown
Hash: 0f7979f4ae91f0a6127fb0a8dd3c1ba8b183b52f
Python version: 3.8.2
Qt version: 5.12.8
Coin version: 4.0.0
[Solved] Is There A Method To Re-Order Frame Views
Re: Is There A Method To Re-Order Frame Views
Found post that clarified issue for me. Had tried moving in tree and fail. No biggee experiment on copy.
wandererfan
Generally, stacking is in creation order.
I didn't know it was possible to move tree entries about like this, except for into/out of Groups or Bodies.
Can't recommend this practice. When I do it things fall off the page or get corrupted and nasty error messages appear.
