[Solved] Error Closing CFD Mesh Task Panel using recent 0.19 Dev Win Build
Moderator: oliveroxtoby
Syres
Post by Syres » Mon Jun 10, 2019 3:31 pm
It would appear that either a commit to the FreeCAD code or the recent change of Qt from 5.6 to 5.12.1 in the Windows 0.19 dev builds has led to an error being generated in the Report View when closing the Cfd Mesh Task Panel (possibly others too):
  File "C:\Users\JPS\AppData\Roaming\FreeCAD\Mod\CfdOF\_TaskPanelCfdMesh.py", line 130, in reject
    self.mesh_process.terminate()
  File "C:\Users\JPS\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdConsoleProcess.py", line 74, in terminate
    self.process.write("terminate\n")
<class 'TypeError'>: 'PySide2.QtCore.QIODevice.write' called with wrong argument types:
  PySide2.QtCore.QIODevice.write(str)
Supported signatures:
  PySide2.QtCore.QIODevice.write(PySide2.QtCore.QByteArray)
I've updated my CfdOf Wb this morning to ensure I've not missed a recent commit to fix this.
The change I made to my local copy of CfdConsoleProcess at line 74 was from:
to:
            try:
            except:
                self.process.write(str.encode("terminate\n"))
I've tested it on both new Py3Qt5 builds as well as older 0.18 Py2Qt4 builds and it appears to work.
I'm open to those with far more Python knowledge as to a more clean solution.
OS: Windows 7 SP 1 (6.1)
Version: 0.19.16935 (Git)
Hash: aa9cd0d91c1db88bf2999a08987a31894e67f7f1
Python version: 3.6.8
Qt version: 5.12.1
oliveroxtoby
Re: Error Closing CFD Mesh Task Panel using recent 0.19 Dev Win Build
Post by oliveroxtoby » Wed Jun 12, 2019 8:22 am
Thanks a lot for this! I have pushed a fix.
Please provide all the information requested in this post before reporting problems with CfdOF.
Syres
Post by Syres » Wed Jun 12, 2019 1:43 pm
Tested your much neater solution successfully, thanks.
