I'm working through the Porous Baffle CFD (SnappyHexMesh) tutorial located at http://www.opensim.co.za/training.html
Everything seems to work fine until I try to write the case to start the analysis job. I get an Error writing the case.
0.0: Checking dependencies...
0.0: Case writer called
0.0: Error writing case:
0.0: name 'CfdMeshRefinement' is not defined
0.0: Write case setup file failed
File "C:\Users\username\AppData\Roaming\FreeCAD\Mod\CfdOF\_TaskPanelCfdSolverControl.py", line 119, in write_input_file_handler
FreeCADGui.doCommand("writer.writeCase()")
File "C:\Users\username\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdCaseWriterFoam.py", line 106, in writeCase
self.setupPatchNames()
File "C:\Users\username\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdCaseWriterFoam.py", line 531, in setupPatchNames
isinstance(regionObj.Proxy, CfdMeshRefinement._CfdMeshRefinement):
NameError: name 'CfdMeshRefinement' is not defined
TIA
