[solved] hisa not found
Moderator: oliveroxtoby
peterko
Re: hisa not found
Post by peterko » Wed Oct 21, 2020 7:57 am
Yes, solved!
Downloading HiSA, please wait...
HiSA downloaded to C:\Users\Peter\AppData\Local\Temp\tmp4kh8fc9m.zip
Extracting HiSA...
Download completed
Building HiSA. Please wait...
Log file: /home/ofuser/OpenFOAM/ofuser-v2006/hisa-master/log.Allwmake
Install completed
HiSA downloaded to C:\Users\Peter\AppData\Local\Temp\tmpvtl2cl32.zip
Extracting HiSA...
Download completed
Install completed
Checking dependencies...
No missing dependencies detected
Don't know why it installed hisa twice, but as long as cfdof works I am happy.
Thanks again Oliver! I will now try some cfd analysis.
peterko
Re: hisa not found
Post by peterko » Wed Oct 21, 2020 8:11 am
Hmm, running the solver still gives the same error:
--> FOAM FATAL ERROR:
Cannot read file "constant/triSurface/.stl" or file "constant/triSurface/.stl.gz"
From static int Foam::fileFormats::STLCore::detectBinaryHeader(const Foam::fileName&)
in file stl/STLCore.C at line 109.
FOAM exiting
ReportViewFoamErrorTrisurf.txt
(6.78 KiB) Downloaded 4 times
Seems the hisa dependency was not the root cause.
Another thing I noticed is that when I try to open the Oracle VirtualBox application I get:
oliveroxtoby
Re: hisa not found
Post by oliveroxtoby » Wed Oct 21, 2020 8:52 pm
FOAM exiting
From the output, it looks like some boundaries may not be defined correctly.
If you save your file and post it here, someone should be able to help.
peterko
Re: hisa not found
Post by peterko » Thu Oct 22, 2020 10:24 am
You are right Oliver, I redefined them and it works! I believe I had a duplicate boundary.
Topic solved.
