Apologies if this is the wrong spot for this post.
I'm trying out FreeCAD specifically to work with IFC files.
So I installed the latest version from the website (FreeCAD 0.18, Libs: 0.18R16131 (Git)), it starts up fine - but whenever I try and load an IFC it crashes. I have tried it with different IFC's but it seems to happen all the time.
I got the IFC's from here ->
http://openifcmodel.cs.auckland.ac.nz/Model?
After searching a bit I found out how to get the log file going.... and this is the output I am get....
Log: Init: Entering event loop
Log: Init: Processing command line files
Log: Module: Part
Log: Loading Part module... done
Err: Traceback (most recent call last):
File "C:\Program Files\FreeCAD 0.18\Mod\Arch\ArchBuildingPart.py", line 519, in attach
lin.coordIndex.setValues([0,1,-1,2,3,-1,4,5,-1])
<class 'AttributeError'>: 'NoneType' object has no attribute 'coordIndex'
File "C:\Program Files\FreeCAD 0.18\Mod\Arch\ArchBuildingPart.py", line 644, in onChanged
self.txt.string.setValue(txt)
<class 'AttributeError'>: 'ViewProviderBuildingPart' object has no attribute 'txt'
..... (more err similar to above)
Log: Loading GUI of Part module... done
Err: Error: Invalid base object
Log: Loading Drawing module... done
.... (more Invalid base objects)
Would appreciate if someone can point me in the right direction - fully accept this may be a PEBKAC issue!
FreeCAD or IFC problem?
- jaggedstudios
Re: FreeCAD or IFC problem?
Moved to IFC subforum
Would you point us to a specific ifc file which you have problems with? Would you post your exact FreeCAD info?
Try these files, they work for me:
- https://github.com/openBIMstandards/Dat ... odel%20IFC
- https://github.com/aothms/IfcOpenHouse
- jaggedstudios
Interestingly I now seem to get a different problem in that it either hangs or crashes completely.
Sometimes it seems to start reading the model correctly - I see the structure list appearing in the side panel - at other times it just displays "unknown" or the model name and nothing underneath it.
I've tried the IFC files you suggested - I've put the log file outputs from each one below....
The installation was directly from the main website for Windows 10 x64 with no other plugins
IFC File - IFCOpenHouse_2X3
Application showed as unresponsive, followed by application crashing
IFC File - IFCOpenHouse_4
Application showed as unresponsive and remained that way - left it for 10+ minutes
Msg: FreeCAD 0.18, Libs: 0.18R16131 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
Log: Time = Sat Sep 7 09:26:08 2019
Log: AppDataSkipVendor = true
Log: AppHomePath = C:/Program Files/FreeCAD 0.18/
Log: AppIcon = freecad
Log: AppTempPath = C:\Users\Beast\AppData\Local\Temp\
Log: BinPath = C:/Program Files/FreeCAD 0.18/bin\
Log: BuildRepositoryURL = git://github.com/FreeCAD/FreeCAD.git releases/FreeCAD-0-18
Log: BuildRevision = 16131 (Git)
Log: BuildRevisionBranch = releases/FreeCAD-0-18
Log: BuildRevisionDate = 2019/07/12 21:08:08
Log: BuildRevisionHash = 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Log: BuildVersionMajor = 0
Log: BuildVersionMinor = 18
Log: Console = 0
Log: CopyrightInfo = © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
Log: Debug = 0
Log: DocPath = C:/Program Files/FreeCAD 0.18/doc\
Log: ExeName = FreeCAD
Log: ExeVendor = FreeCAD
Log: ExeVersion = 0.18
Log: LoggingFile = 1
Log: LoggingFileName = C:\Users\Beast\AppData\Roaming\FreeCAD\FreeCAD.log
Log: MaintainerUrl = http://www.freecadweb.org/wiki/Main_Page
Log: PATH = C:\Program Files\FreeCAD 0.18\bin\Library\bin;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;c:\programdata\oracle\java\javapath;c:\windows\system32;c:\windows;c:\windows\system32\wbem;c:\windows\system32\windowspowershell\v1.0\;c:\program files\git\cmd;c:\program files (x86)\gtksharp\2.12\bin;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Microsoft SQL Server\140\Tools\Binn\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn\;C:\Program Files\Microsoft SQL Server\140\Tools\Binn\;C:\Program Files\Microsoft SQL Server\140\DTS\Binn\;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Java\jdk1.8.0_151\bin;C:\Users\Beast\AppData\Local\Microsoft\WindowsApps;
Log: PythonSearchPath = C:\Program Files\FreeCAD 0.18\bin\python36.zip;C:\Program Files\FreeCAD 0.18\bin\DLLs;C:\Program Files\FreeCAD 0.18\bin\lib;C:\Program Files\FreeCAD 0.18\bin
Log: RunMode = Gui
Log: SplashAlignment = Bottom|Left
Log: SplashInfoColor = #c8c8c8
Log: SplashScreen = freecadsplash
Log: SplashTextColor = #ffffff
Log: StartWorkbench = StartWorkbench
Log: SystemParameter = C:\Users\Beast\AppData\Roaming\FreeCAD\system.cfg
Log: UserAppData = C:\Users\Beast\AppData\Roaming\FreeCAD\
Log: UserHomePath = C:\Users\Beast\Documents
Log: UserParameter = C:\Users\Beast\AppData\Roaming\FreeCAD\user.cfg
Log: Verbose =
Log: Create Application
Log: Run App init script
Log: Init: starting App::FreeCADInit.py
Log: Init: Searching for modules...
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\AddonManager... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Arch... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Complete... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Draft... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Drawing... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Fem... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Idf... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Image... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Import... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Inspection... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Material... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Measure... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Mesh... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\MeshPart... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\OpenSCAD... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Part... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\PartDesign... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Path... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Plot(Init.py not found)... ignore
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Points... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Raytracing... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Robot... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Ship(Init.py not found)... ignore
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Show(Init.py not found)... ignore
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Sketcher... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Spreadsheet... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Start... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Surface... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\TechDraw... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Test... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Tux(Init.py not found)... ignore
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Web... done
Log: Using C:\Program Files\FreeCAD 0.18\Mod as module path!
Log: System path after init:
Log: C:\Program Files\FreeCAD 0.18\bin
Log: C:\Program Files\FreeCAD 0.18\Mod\AddonManager
Log: C:\Program Files\FreeCAD 0.18\Mod\Arch
Log: C:\Program Files\FreeCAD 0.18\Mod\Complete
Log: C:\Program Files\FreeCAD 0.18\Mod\Draft
Log: C:\Program Files\FreeCAD 0.18\Mod\Drawing
Log: C:\Program Files\FreeCAD 0.18\Mod\Fem
Log: C:\Program Files\FreeCAD 0.18\Mod\Idf
Log: C:\Program Files\FreeCAD 0.18\Mod\Image
Log: C:\Program Files\FreeCAD 0.18\Mod\Import
Log: C:\Program Files\FreeCAD 0.18\Mod\Inspection
Log: C:\Program Files\FreeCAD 0.18\Mod\Material
Log: C:\Program Files\FreeCAD 0.18\Mod\Measure
Log: C:\Program Files\FreeCAD 0.18\Mod\Mesh
Log: C:\Program Files\FreeCAD 0.18\Mod\MeshPart
Log: C:\Program Files\FreeCAD 0.18\Mod\OpenSCAD
Log: C:\Program Files\FreeCAD 0.18\Mod\Part
Log: C:\Program Files\FreeCAD 0.18\Mod\PartDesign
Log: C:\Program Files\FreeCAD 0.18\Mod\Path
Log: C:\Program Files\FreeCAD 0.18\Mod\Plot
Log: C:\Program Files\FreeCAD 0.18\Mod\Points
Log: C:\Program Files\FreeCAD 0.18\Mod\Raytracing
Log: C:\Program Files\FreeCAD 0.18\Mod\Robot
Log: C:\Program Files\FreeCAD 0.18\Mod\Ship
Log: C:\Program Files\FreeCAD 0.18\Mod\Show
Log: C:\Program Files\FreeCAD 0.18\Mod\Sketcher
Log: C:\Program Files\FreeCAD 0.18\Mod\Spreadsheet
Log: C:\Program Files\FreeCAD 0.18\Mod\Start
Log: C:\Program Files\FreeCAD 0.18\Mod\Surface
Log: C:\Program Files\FreeCAD 0.18\Mod\TechDraw
Log: C:\Program Files\FreeCAD 0.18\Mod\Test
Log: C:\Program Files\FreeCAD 0.18\Mod\Tux
Log: C:\Program Files\FreeCAD 0.18\Mod\Web
Log: C:\Program Files\FreeCAD 0.18\bin\Library\bin
Log: C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler
Log: c:\programdata\oracle\java\javapath
Log: c:\windows\system32
Log: c:\windows
Log: c:\windows\system32\wbem
Log: c:\windows\system32\windowspowershell\v1.0\
Log: c:\program files\git\cmd
Log: c:\program files (x86)\gtksharp\2.12\bin
Log: C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common
Log: C:\WINDOWS\system32
Log: C:\WINDOWS
Log: C:\WINDOWS\System32\Wbem
Log: C:\WINDOWS\System32\WindowsPowerShell\v1.0\
Log: C:\WINDOWS\System32\OpenSSH\
Log: C:\Program Files (x86)\Microsoft SQL Server\140\Tools\Binn\
Log: C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn\
Log: C:\Program Files\Microsoft SQL Server\140\Tools\Binn\
Log: C:\Program Files\Microsoft SQL Server\140\DTS\Binn\
Log: C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR
Log: C:\WINDOWS
Log: C:\Program Files (x86)\Java\jdk1.8.0_151\bin
Log: C:\Users\Beast\AppData\Local\Microsoft\WindowsApps
Log:
Log: Init: App::FreeCADInit.py done
Log: Init: Creating Gui::Application and QApplication
Log: Local server 'FreeCAD' started
Log: OpenGL version is: 4.6 (4.6.0 NVIDIA 436.15)
Log: Run Gui init script
Log: Init: Running FreeCADGuiInit.py start script...
Log: Init: Searching modules...
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Idf(InitGui.py not found)... ignore
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Measure(InitGui.py not found)... ignore
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Plot... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Ship... done
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Show(InitGui.py not found)... ignore
Log: Init: Initializing C:\Program Files\FreeCAD 0.18\Mod\Tux... done
Log: Init: Loading FreeCAD GUI
Log: Init: Running FreeCADGuiInit.py start script... done
Log: Init: Activating default workbench StartWorkbench
Log: Loading GUI of Web module... done
Log: Loading GUI of Start module... done
Log: Loading Start module... done
Log: Init: Showing main window
Log: Main window restored
Log: Show main window
Log: Toolbars restored
Log: 3Dconnexion device not attached.
Log: Module: Part
Msg: Unable to create a roofMsg: Unable to create a roof
Log: Time = Sat Sep 7 09:27:17 2019
Log: Console = 0
Log: Debug = 0
Log: RunMode = Gui
Log: Verbose =
Log: c:\windows
Log: C:\WINDOWS
Log: C:\WINDOWS
Log:
Log: Module: Part
Log: Hide main window
Log: Finish: Event loop left
Log: Destruct Gui::Application
Log: FreeCAD terminating...
Log: Saving system parameter...
Log: Saving system parameter...done
Log: Saving user parameter...
Log: Saving user parameter...done
- jaggedstudios
Addendum:
I tried this IFC file: http://openifcmodel.cs.auckland.ac.nz/Model/Details/314
It seemed to do better - it seemed to be working, I got the structure list appearing then it started importing the IFC objects - got to 100% then hung.... I went for a coffee, when I came back it had crashed out.
Log: Time = Sat Sep 7 11:01:35 2019
Log: Console = 0
Log: Debug = 0
Log: RunMode = Gui
Log: Verbose =
Log: c:\windows
Log: C:\WINDOWS
Log: C:\WINDOWS
Log:
Log: Module: Part
File "C:\Program Files\FreeCAD 0.18\Mod\Arch\ArchBuildingPart.py", line 604, in onChanged
self.fon.name = vobj.FontName
<class 'AttributeError'>: 'ViewProviderBuildingPart' object has no attribute 'fon'
File "C:\Program Files\FreeCAD 0.18\Mod\Arch\ArchBuildingPart.py", line 609, in onChanged
self.fon.size = fs
File "C:\Program Files\FreeCAD 0.18\Mod\Arch\ArchBuildingPart.py", line 561, in updateData
self.onChanged(obj.ViewObject,"ShowLabel")
self.fon.size = fs
File "C:\Program Files\FreeCAD 0.18\Mod\Arch\ArchBuildingPart.py", line 552, in updateData
self.onChanged(obj.ViewObject,"OverrideUnit")
self.fon.size = fs
self.fon.size = fs
Wrn: Fregadero de Meson:500 mm x 500 mm - Privado:1963452 has an invalid shape
Msg: Unable to create a roofWrn: Armario en L:Armario en L:2011381 has an invalid shape
Wrn: Armario en L:Armario en L:2014787 has an invalid shape
Wrn: Cajon Meson 02 D:1200x800x580 mm:2079718 has an invalid shape
Msg: Unable to create a roofWrn: Television_Panasonic_54quot_Plasma_Wall_Mounted_10523:Television_Panasonic_54quot_Plasma_Wall_Mounted_10523:2168314 has an invalid shape
For ease of reading: please edit your posts and use code tags </> around your log output.
in ifc preferences change from full parametric to Arch Component. Just for testing if the models than load better.
