Certain IFC file is not properly imported in V0.19?
This forum section is only for IFC-related issues
Roy_043
Post by Roy_043 » Sat Oct 19, 2019 10:37 am
An IFC file posted in another topic is not properly imported in V0.19. The window solids are missing.
V0.19 (problem):
OS: Windows 8.1 (6.3)
Version: 0.19.18540 (Git)
Hash: fa5d34508bb3e82437acbdbdba1e4c533e0c1c30
Python version: 3.6.8
Qt version: 5.12.1
V0.18 (OK):
OS: Windows 8.1
Word size of FreeCAD: 32-bit
Version: 0.18.16093 +38 (Git)
Branch: (HEAD detached at 0.18.3)
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 2.7.14
OCC version: 7.2.0
Windows_Opening-Hinge_Favorol-Papaux_FP-PVC_1V.ifc
(158.49 KiB) Downloaded 24 times
Roy_043
Re: Certain IFC file is not properly imported in V0.19?
Post by Roy_043 » Sat Oct 19, 2019 11:55 am
There is also an issue in V0.18.
If you explode the window until you have solids, you will see that there are 6 solids that appear to be glass. I think that 4 of those are actually seals that should go around the glass and the window frame.
bernd
Post by bernd » Sun Oct 20, 2019 11:35 am
it works if the shape is imported only ...
make a new document and run ... do not forget to set the path to the file ...
import ifcopenshell, os, Part
from ifcopenshell import geom
settings = ifcopenshell.geom.settings()
settings.set(settings.USE_BREP_DATA,True)
settings.set(settings.SEW_SHELLS,True)
settings.set(settings.USE_WORLD_COORDS,True)
ifcfile = '/home/hugo/Desktop/Windows_Opening-Hinge_Favorol-Papaux_FP-PVC_1V.ifc'
f = ifcopenshell.open(ifcfile)
f.by_type('IfcProject')
p = f.by_id(3629)
r = p.Representation
print(p, '\n', r)
cr = ifcopenshell.geom.create_shape(settings, p)
brep = cr.geometry.brep_data
shape = Part.Shape()
shape.importBrepFromString(brep)
Part.show(shape)
bernd
Post by bernd » Sun Oct 20, 2019 11:37 am
but
>>> shape.isValid()
False
thus it is not imported, because only valid shapes are imported.
Roy_043
Post by Roy_043 » Mon Oct 21, 2019 8:09 am
@bernd: Thank you for your analysis.
Retesting the V0.19 import I now see there is actually an error message in the Report view:
Failed to rebuild a valid solid for object Window
Apparently an IFC (this one created in ArchiCAD) can contain invalid solids. I do not know what is better: Rejecting an object for such a reason (V0.19), or importing it anyway (V0.18). In this case the imported window can be exploded into solids, which the user might then check with Part CheckGeometry. After deleting the bad solids (related to glazing and seals?) the remaining solids (related to the frame) would still be usable. But for a bigger project this would probably not be feasible.
bernd
Post by bernd » Mon Oct 21, 2019 8:51 am
any IFC can contain lots of invalid solids ... IfcOpenShell and IfcPlusPlus have very much improved to create valid data even from bad ifc data. It very much depends on the one behind the keybord also. If bad geometry in the CAD is accepted than the ifc export from the CAD will contain these bad geometry. A window is not a good example for this, because normally the geometry is costructed by the CAD.
bernd
Post by bernd » Mon Oct 21, 2019 8:57 am
We may should import it anyway, or make it an option.
yorik
Site Admin
Post by yorik » Mon Oct 21, 2019 7:24 pm
Yes I agree, we should make that optional. Working on it now! *EDIT* git commit 7767103f9c
Roy_043
Post by Roy_043 » Wed Oct 23, 2019 7:47 am
@yorik: That was fast! Thank you.
