[SOLVED] Build on Fedora 29
mtsinc
Post by mtsinc » Mon Mar 04, 2019 7:44 pm
I've a nice laundry list for FreeCAD, mostly having to do with making it more conformant with generally-accepted GUI practices and I'd like to see if I can implement them, but I'm afraid the current CompileOnLinux instructions are letting me down.
This is what I've seen when following the "Out-of-source build" instructions
[timh@a64a freecad]$ uname -a
Linux a64a.mousetech.com 4.20.13-200.fc29.x86_64 #1 SMP Wed Feb 27 19:42:55 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
[timh@a64a freecad]$ cat /etc/redhat-release
Fedora release 29 (Twenty Nine)
[timh@a64a freecad]$ mkdir freecad-build
[timh@a64a freecad]$ cd freecad-build/
[timh@a64a freecad-build]$ cmake ../freecad-code -DCMAKE_BUILD_TYPE=Debug .
CMake Error: The source directory "/home/timh/freecad/freecad-build" does not appear to contain CMakeLists.txt.
Specify --help for usage, or press the help button on the CMake GUI.
CMake is 3.12.1, gcc is 8.3.1 (20190223), g++ is same (Red Hat 8.3.1-2)
Also, when I build in-source, I get this troubling message:
/usr/bin/ld: /usr/lib/gcc/x86_64-redhat-linux/8/../../../../lib64/libboost_python.a(list.o): relocation R_X86_64_PC32 against symbol `PyList_Type' can not be used when making a shared object; recompile with -fPIC
This is for boost-python2-1.66.0-14
Jee-Bee
Re: Build on Fedora 29
Post by Jee-Bee » Mon Mar 04, 2019 8:33 pm
This has nothing to do with techdraw. Please can one of the moderators move this topic to install/ compile?
mtsinc
Post by mtsinc » Thu Mar 07, 2019 2:13 pm
Thanks. I looked for a more suitable forum, but somehow was blind.
Actually, I wonder about FreeCAD and Fedora 29 in general. All sorts of things broke when I upgraded from Fedora 28. I downloaded the SRPM for FreeCAD and it fails to build.
Thankfully, AppImage works. Plus, I've become addicted to several features of FreeCAD 18, anyway, so the official release would be a painful step back.
paullee
Post by paullee » Thu Mar 07, 2019 2:35 pm
Hi, I am not a programmer.
Recently, for debugging, I use a numbers of days in trying compiling on Fedora 29 also.
Successfully to build 'In- source' , though not fully tested afterwards.
UsIng appImagr akso.
https://forum.freecadweb.org/viewtopic. ... 1&start=10
mtsinc
Post by mtsinc » Thu Mar 07, 2019 5:10 pm
Thanks! It looks like the USE_EXTERNAL_PIVY might be what did the trick.
I did have to completely delete my current project and re-pull it, though. There is, alas, apparently no "clean" option for what CMake does.
Would have been nice to use the out-of-source build option, though.
mtsinc
Re: [SOLVED] Build on Fedora 29
Post by mtsinc » Tue Apr 16, 2019 9:06 pm
Solved again! Didn't even need PIVY this time. I've learned somewhat about CMake.
To separate source and build starting from git, this command sequence will work:
NOTE: My current project requires nearly 9GB of disk space!
# 1. Pull the source archive and override its root directory name locally:
$ git clone (freecard repo url) freecad-code
# 2. Create the build/doc directory:
# 3. CMake the Makefiles:
$ CMake -S freecad-code -B freecad-build
# 4. Now cd and build:
$ cd freecad-build
$ make
# 5. Optionally, make documentation
$ make DevDoc
As a shell script, edit as needed:
#!/bin/sh
FREECODE_REPO_URL=TBS
git clone ${FREECODE_REPO_URL} freecad-code
mkdir freecad-build
cd freecad-build
make
make DevDoc
kkremitzki
Post by kkremitzki » Tue Apr 16, 2019 10:01 pm
Glad to hear you got it working--and I bet the DevDocs are making up a big chunk of that size, IIRC they're pretty big.
