Building Libs for Windows Debug Version with VS2017/Qt5.12
apeltauer
Re: Building Libs for Windows Debug Version with VS2017/Qt5.12
Post by apeltauer » Mon Mar 11, 2019 9:50 am
Problem solved:
Swig version 3.0.12 is too old for python 3.7 :)
Found this discussion (https://stackoverflow.com/questions/530 ... xcess-args)
After modifying pyrun.swg, the code is running and i can access coin3d via pivy.
Next step, check if all tests are running....
Site Admin
Post by wmayer » Mon Mar 11, 2019 11:22 am
Good news!
Once you finished the stuff can you report which modifications you had to make in the source code, please?
apeltauer
Post by apeltauer » Mon Mar 11, 2019 1:19 pm
Modification in SWIG:
Lib\python\pyrun.swg, methode:
SWIG_Python_NewShadowInstance(SwigPyClientData *data, PyObject *swig_this)
line1365 looks now like this...
#if PY_VERSION_HEX >= 0x03000000
    PyObject *empty_args = PyTuple_New(0);
    if(empty_args){
      inst = ((PyTypeObject*) data->newargs)->tp_new((PyTypeObject*) data->newargs, empty_args, Py_None);
      if (inst) {
        PyObject_SetAttr(inst, SWIG_This(), swig_this);
        Py_TYPE(inst)->tp_flags &= ~Py_TPFLAGS_VALID_VERSION_TAG;
apeltauer
Post by apeltauer » Wed Mar 13, 2019 3:31 am
Short update:
My Libpack for debug is almost done. Compiling Fc works, the Test in the debug version works almost too. Except a crash at the end. Will figure this out.
Now I need to create a new cmake Libpack file to find all dependencies.
At this time I had no luck to get Fem running. Compiling Netgen was no problem. But building Smesh is a little harder with all the dependencies needed....
BR Manuel
Site Admin
Post by wmayer » Wed Mar 13, 2019 8:35 am
Could be the area module when using boost.python. If using this option you have to make sure to link against the debug Python library which is a bit tricky.
On github there is also an smesh version available which doesn't require all the med and hdf5 stuff. I recommend using this one because it's much easier to build.
apeltauer
Post by apeltauer » Mon Mar 18, 2019 4:28 pm
Update:
The debug build works. The cmake Adaption and a new Libpack.cmake file just works good.
The debug build still fails at two points.
1. Numpy is a little hard to get for the debug version
2. Still crashes after the test finish with no error in the arch tests. (Boost python is linked against pyhton_d)
3. I had no time to check the smesh stuff again.
Release version can be build now. Some depencies are still not working, figure that out tomorrow.
After that I would like to upload my Libpack. Does someone wants to give it a try?
sgrogan
Post by sgrogan » Mon Mar 18, 2019 8:41 pm
I'm very interested in both debug and release versions.
"fight the good fight"
Site Admin
Post by wmayer » Tue Mar 19, 2019 9:05 am
And please add the .pdb files into the Libpack directory as otherwise the debug versions are of limited help.
apeltauer
Post by apeltauer » Tue Mar 19, 2019 1:30 pm
Update:
Release build works just fine. Tests are good except of one in the ship workbench. see pic:
Also the web stuff does not work yet. In qt5 the webkit is depricated for the webenging. I tried to merge the PR (https://github.com/FreeCAD/FreeCAD/pull/1937) from mumme74. But it throws an exception.
For now their is no start page...
apeltauer
Post by apeltauer » Tue Mar 19, 2019 1:54 pm
Here is my first draft of the new lipack:
Cmake changes can be found here:
https://github.com/apeltauer/FreeCAD/tr ... ack_12.1.1
The libpack and the pdbs can be found here:
https://github.com/apeltauer/FreeCAD/releases
I hope someone can test the libpack and can tell me if it works...
After a positive feedback i can create PR to the FC main branch...
Br Manuel
