Building Libs for Windows Debug Version with VS2017/Qt5.12
sgrogan
Re: Building Libs for Windows Debug Version with VS2017/Qt5.12
Post by sgrogan » Tue Mar 19, 2019 11:17 pm
apeltauer wrote:
Tue Mar 19, 2019 1:54 pm
I hope someone can test the libpack and can tell me if it works...
I tried to build with your tag,
In CMake I had to manually set all the boost lib paths (I only set the release paths), the includes were detected automatically.
I then had to set the QT5 flag.
Running VS2017 Release x64
gives the following errors
Severity	Code	Description	Project	File	Line	Suppression State
Error	C2057	expected constant expression	FreeCADGui	C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.12.25827\include\vector	682
Error	C1903	unable to recover from previous error(s); stopping compilation	FreeCADGui	C:\Users\Chris\GitHub\FreeCADA\src\Gui\ViewProviderPythonFeature.cpp	1081
Error	LNK1181	cannot open input file '..\Gui\Release\FreeCADGui.lib'	FreeCADMain	C:\Users\Chris\GitHub\buildlp12\src\Main\LINK	1
Error	LNK1181	cannot open input file '..\..\..\Gui\Release\FreeCADGui.lib'	PointsGui	C:\Users\Chris\GitHub\buildlp12\src\Mod\Points\Gui\LINK	1
Error	LNK1181	cannot open input file '..\..\..\Gui\Release\FreeCADGui.lib'	InspectionGui	C:\Users\Chris\GitHub\buildlp12\src\Mod\Inspection\Gui\LINK	1
Error	LNK1181	cannot open input file '..\..\..\Gui\Release\FreeCADGui.lib'	QtUnitGui	C:\Users\Chris\GitHub\buildlp12\src\Mod\Test\Gui\LINK	1
Error	LNK1181	cannot open input file '..\..\..\Gui\Release\FreeCADGui.lib'	ImageGui	C:\Users\Chris\GitHub\buildlp12\src\Mod\Image\Gui\LINK	1
Error	LNK1181	cannot open input file '..\..\..\Gui\Release\FreeCADGui.lib'	StartGui	C:\Users\Chris\GitHub\buildlp12\src\Mod\Start\Gui\LINK	1
Error	C2057	expected constant expression	MeshGui	C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.12.25827\include\vector	682
Error	C1903	unable to recover from previous error(s); stopping compilation	MeshGui	C:\Users\Chris\GitHub\FreeCADA\src\Mod\Mesh\Gui\ViewProviderPython.cpp	29
Error	LNK1181	cannot open input file '..\..\..\Gui\Release\FreeCADGui.lib'	ReverseEngineeringGui	C:\Users\Chris\GitHub\buildlp12\src\Mod\ReverseEngineering\Gui\LINK	1
Error	LNK1181	cannot open input file '..\Gui\Release\FreeCADGui.lib'	FreeCADGuiPy	C:\Users\Chris\GitHub\buildlp12\src\Main\LINK	1
Error	LNK1181	cannot open input file '..\..\..\Gui\Release\FreeCADGui.lib'	SpreadsheetGui	C:\Users\Chris\GitHub\buildlp12\src\Mod\Spreadsheet\Gui\LINK	1
Error	LNK1181	cannot open input file '..\..\..\Gui\Release\FreeCADGui.lib'	DrawingGui	C:\Users\Chris\GitHub\buildlp12\src\Mod\Drawing\Gui\LINK	1
Error	LNK1181	cannot open input file '..\..\..\Gui\Release\FreeCADGui.lib'	RobotGui	C:\Users\Chris\GitHub\buildlp12\src\Mod\Robot\Gui\LINK	1
Error	LNK1181	cannot open input file '..\..\..\Gui\Release\FreeCADGui.lib'	RaytracingGui	C:\Users\Chris\GitHub\buildlp12\src\Mod\Raytracing\Gui\LINK	1
Error	LNK1181	cannot open input file '..\..\..\Gui\Release\FreeCADGui.lib'	PartGui	C:\Users\Chris\GitHub\buildlp12\src\Mod\Part\Gui\LINK	1
Error	LNK1181	cannot open input file '..\..\Part\Gui\Release\PartGui.lib'	ImportGui	C:\Users\Chris\GitHub\buildlp12\src\Mod\Import\Gui\LINK	1
Error	LNK1181	cannot open input file '..\..\Part\Gui\Release\PartGui.lib'	MeshPartGui	C:\Users\Chris\GitHub\buildlp12\src\Mod\MeshPart\Gui\LINK	1
Error	LNK1181	cannot open input file '..\..\Part\Gui\Release\PartGui.lib'	SurfaceGui	C:\Users\Chris\GitHub\buildlp12\src\Mod\Surface\Gui\LINK	1
Error	LNK1181	cannot open input file '..\..\Part\Gui\Release\PartGui.lib'	PathGui	C:\Users\Chris\GitHub\buildlp12\src\Mod\Path\Gui\LINK	1
Error	LNK1181	cannot open input file '..\..\..\Gui\Release\FreeCADGui.lib'	TechDrawGui	C:\Users\Chris\GitHub\buildlp12\src\Mod\TechDraw\Gui\LINK	1
Error	LNK1181	cannot open input file '..\..\Part\Gui\Release\PartGui.lib'	SketcherGui	C:\Users\Chris\GitHub\buildlp12\src\Mod\Sketcher\Gui\LINK	1
Error	LNK1181	cannot open input file '..\..\Sketcher\Gui\Release\SketcherGui.lib'	PartDesignGui	C:\Users\Chris\GitHub\buildlp12\src\Mod\PartDesign\Gui\LINK	1
"fight the good fight"
apeltauer
Post by apeltauer » Wed Mar 20, 2019 6:02 am
Thanks for testing.
Set Qt5 depends on the main cmak file in line 180
    IF(DEFINED ENV{FREECAD_LIBPACK_DIR})
      set(FREECAD_LIBPACK_DIR $ENV{FREECAD_LIBPACK_DIR} CACHE PATH  "Directory of the FreeCAD LibPack")
      MESSAGE(STATUS "Found libpack env variable: ${FREECAD_LIBPACK_DIR}")
      IF(EXISTS ${FREECAD_LIBPACK_DIR}/lib/Qt53DCore.lib)
        OPTION(BUILD_QT5 "Build with Qt5." ON)
So basically if you set a environment variable named "FREECAD_LIBPACK_DIR" to to the libpack qt5 should be enabled.
Can you please test this first? Right now cant understand why the boost stuff is not found automatically...
Can you please have a look why the project "FreeCADGui" cant be build? I thinks this fails your build...
sgrogan
Post by sgrogan » Wed Mar 20, 2019 9:21 pm
Males sense. I either set the path in cmake-gui or pass as a command line switch. It's a minor inconvience for me to set an environment variable because I'm using VS2013/15/17 32 and 64 bit. I will check if setting the variable makes a difference with finding the boost libs.
From my error above it had something to do with the C++ runtimes, updating VS2017 fixed it.
I only get an error for the Web WB when running the self-tests, no Ship error.
Did you build QT with SSL support? I don't see the dll's. At least when using QTWebkit ssl is required by the Start page.
OS: Windows 7 SP 1 (6.1)
Version: 0.19.16182 (Git)
Branch: (HEAD detached at LibPack_12.1.1)
Hash: c01936fa495456fcb52b4e78f859c78e82bc9095
Python version: 3.7.2
Qt version: 5.12.1
apeltauer
Post by apeltauer » Wed Mar 20, 2019 9:33 pm
Sounds good so far... :)
I didn’t build qt myself, I used the pre build of qt which can be downloaded by qt...
I will check the ssl stuff tomorrow...
sgrogan
Post by sgrogan » Wed Mar 20, 2019 9:45 pm
It's built without ssl.
Amazing work here :) Thanks :D
Do you have any desire to build (or direct me) to build a 32 bit version? I don't think we would need the debug libs.
apeltauer
Post by apeltauer » Thu Mar 21, 2019 6:45 am
No, not really... :)
Just compiling the binaries is just one thing, but with all the python stuff, pyside2, pivy,.... this is another big task...
I just cleaned my github repo.
The cmake changes are store here (https://github.com/apeltauer/FreeCAD/tr ... ibpack_v12)
Site Admin
Post by wmayer » Thu Mar 21, 2019 8:09 am
The Qt binaries you get with the installer have SSL support enabled. In case SSL doesn't work then maybe you forgot to add the OpenSSL dlls to the LibPack. When looking at the dependencies of the QtNetwork module (using the Dependency Walker) there shouldn't be listed the OpenSSL dlls. Instead they are loaded fully dynamically at runtime.
Site Admin
Post by wmayer » Thu Mar 21, 2019 8:26 am
It makes sense to automatically activate the Qt5 option in case the LibPack includes Qt5 stuff. However, you shouldn't check for Qt53DCore because in FreeCAD we don't use Qt3D and there is no guarantee that all future LibPacks offer this file. Better you check for Qt5Core.
At the moment the top-level CMake file duplicates a lot of code to find the needed libraries. There is the standard way how it's done on all Linux distribution and there is this option FREECAD_LIBPACK_USE. Years ago peterl94 had the great idea to harmonize this a bit using the CLBundler project which allows is to use the LibPack the way how it's done on Linux.
Therefore I would like to remove all the duplicated code.
Now in order to identify your LibPack you only have to add the file MANIFEST.db to the root directory of the LibPack.
The changes you made for FindOpenCasCade.cmake are problematic because this will make it fail on other OS than Windows because there is no distinction in the file namen between release and debug versions.
apeltauer
Post by apeltauer » Thu Mar 21, 2019 11:57 am
Will change this to Qt5Core...
You are totally right with the duplicated code. I just dont know what the manifest contains and how it was build.
I try to use the CLBundler cmake file and make my changes their.
Will change this back and make a use case if "FREECAD_LIBPACK_USE" then....
Site Admin
Post by wmayer » Thu Mar 21, 2019 12:31 pm
I don't know but it may suffice to create a dummy file with this name. AFAIK inside the cmake file it's only tested for the existence of the files but not its content.
