[Solved]local build run starts global installed one
Post by bernd » Fri Oct 18, 2019 9:39 am
I try to explain what is happening here on a Debian Buster Linux. I have no idea why ...
I have the following build installed on /usr/local
OS: Debian GNU/Linux 10 (buster) (KDE//usr/share/xsessions/plasma)
Version: 0.19.18527 (Git)
Build type: Unknown
Hash: 1f5f00e655b573489c3e897efd5d87e93cf77f15
Python version: 3.7.3
Qt version: 5.11.3
Locale: German/Switzerland (de_CH)
If this is started I get ...
hugo@Ahorn:~$ FreeCAD
FreeCAD 0.19, Libs: 0.19R18527 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
everything with this is fine.
In my FreeCAD build directory I am at master head somewhere around 0.19.18559
$ git log -1
commit f9117960469682b2ef7f9bb96940a50ba1740060 (HEAD -> femtmp, sfmaster/master, origin/femtmp)
Author: Jean-Marie Verdun <jmverdun3@gmail.com>
Date:   Wed Oct 16 19:18:37 2019 +0200
    Fix auth base64 computation when HMAC return string contains \0 character
Building FreeCAD works fine but if I run in the Builddirectory by invoking
./bin/FreeCAD
it does not start the FreeCAD from build directory, it uses libs from usr local ...
~/Documents/dev/freecad/freecadbhb_dev/build$ ./bin/FreeCAD
But it does not load all from /usr/local, just some parts. I have no idea which one. For sure all Python modules is taken from build directory. This is why I still can develop without installing :-)
But if something bigger has changed I need to install FreeCAD to run it from build directory. This has for sure worked before. I allready did a rebuild. I have no idea where to look for a solution for this.
anyone has an idea how to debug or where to look.
cheers bernd
Re: local build run starts global installed one
Post by wmayer » Fri Oct 18, 2019 2:44 pm
Do you have set LD_LIBRARY_PATH or are the FreeCAD libs installed to a directory listed in ld.so.conf?
What does ldd <Path_to_an_so_file_in_your_build_dir> return?
Do you use the RPATH option?
Post by bernd » Sat Oct 19, 2019 9:44 pm
$ printenv LD_LIBRARY_PATH
/usr/local/lib::/opt/netgen/lib
berndsFreeCAD/build$
berndsFreeCAD/build$ ldd lib/FreeCAD.so
        linux-vdso.so.1 (0x00007fff10bca000)
        libFreeCADApp.so => /usr/local/lib/libFreeCADApp.so (0x00007f449e0a5000)
        libFreeCADBase.so => /usr/local/lib/libFreeCADBase.so (0x00007f449dde8000)
        libxerces-c-3.2.so => /lib/x86_64-linux-gnu/libxerces-c-3.2.so (0x00007f449da3b000)
        ... dozens more libs in /lib/...
aha this should not /usr/local/lib/ ...
Post by bernd » Sat Oct 19, 2019 9:45 pm
but I did not set it environment variable. My Debian install is quite new. I did a reinstall after four years a few weeks ago (two or three)
Post by bernd » Sat Oct 19, 2019 9:47 pm
ha I needed to set LD_LIBRARY_PATH for IFCPlusPlus ... https://gist.github.com/berndhahnebach/ ... lus-sh-L95
Post by bernd » Sat Oct 19, 2019 9:52 pm
if I use export LD_LIBRARY_PATH=/opt/netgen/lib only it works great and IfcPlusPlus still runs fine ... May be it is no longer needed. May be someone fixed it in IFCPlusPlus cmake ...
Thanks very much werner. As quite often, I understood your post and what I did, but I would have never did it without your hints. :D
Post by wmayer » Sun Oct 20, 2019 10:14 am
There are two ways to solve the problem:
  1. The first you figured out by removing /usr/local/lib from LD_LIBRARY_PATH
  2. The other way would be to adjust your cmake settings not to install FreeCAD libs directly to /usr/local/lib but into a sub-directory e.g. /usr/local/lib/freecad
Post by bernd » Sun Oct 20, 2019 11:02 am
  1. The other way would be to adjust your cmake settings not to install FreeCAD libs directly to /usr/local/lib but into a sub-directory e.g. /usr/local/lib/freecad
another thanks for that one which is easy to but one need to know about :)
