Compiling with custom builds
gaggedegg
Post by gaggedegg »
I'm trying to compile FreeCAD with minimum builds from CMAKE. I have only selected below mentioned builds in CMAKE
  • Build_GUI
  • Build_Material
  • Build_Mesh
  • Build_Mesh_Part
  • Build_Part
  • Build_QT5
  • Build_Raytracing
  • Build_Web
I'm getting 18 Builds to succeed and 15 to fail. Are there any dependencies required to build successfully all the builds? If so can you please mention what other builds should I include here? Also I only want 'part and raytracing workbench' to work upon, so which builds do I require for them?
OS: Windows 10 Pro x64
IDE: Visual Studio Community 2019 (MSVC 2015)
CMAKE: 3.17.5
LibPack: FreeCADLibs_12.1.6_x64_VC15 (https://github.com/FreeCAD/FreeCAD/rele ... 64_VC15.7z)
SourceCode: https://github.com/FreeCAD/FreeCAD.git
Founder
Re: Compiling with custom builds
Post by wmayer »
gaggedegg wrote: Wed Oct 07, 2020 4:54 am and 15 to fail
What are the error messages?
gaggedegg
Post by gaggedegg »
wmayer wrote: Wed Oct 07, 2020 8:15 am
There are some link errors. I guess it's probably because I haven't build some dependencies. Like, when building 'PartDesignGui', there is a fatal error stating that 'cannot open input file 'SketcherGui.lib' ' and it's obvious because I have not checked 'Build_Sketcher' in CMAKE while configuring and generating files. :oops:
I think I should close this topic now!
Thank you for asking wmayer!
Post by Kunda1 »
Mod edit: Moved to Install/Compile subforum
gaggedegg
Post by gaggedegg »
Kunda1 wrote: Wed Oct 07, 2020 2:56 pm Mod edit: Moved to Install/Compile subforum
8-)
sgrogan
Post by sgrogan »
gaggedegg wrote: Wed Oct 07, 2020 10:37 am I think I should close this topic now!
No need to close anything.
It seems your on your way yourself, but don't hesitate to post these issues in this sub-forum, we all gain knowledge from each other.
Some time ago ian.rees did some work on this to give a warning in CMake when disabled projects were dependencies of built projects. I am still looking for the old thread.
EDIT: See here https://github.com/FreeCAD/FreeCAD/pull/3939
"fight the good fight"
gaggedegg
Post by gaggedegg »
sgrogan wrote: Wed Oct 07, 2020 8:38 pm
Okay got it, sgrogan! Thank you!
