FreeCad Compile Error
enderelohim
Post by enderelohim » Fri Nov 13, 2020 4:39 pm
Hello there i'm trying to compile FreeCad by following the link:
https://wiki.freecadweb.org/Compile_on_ ... utdated.29
But when it come to use Cmake there are problems.
What should i do?
sgrogan
Re: FreeCad Compile Error
Post by sgrogan » Fri Nov 13, 2020 7:01 pm
What should i do?
Set the generator to x64
"fight the good fight"
Site Admin
Post by wmayer » Sat Nov 14, 2020 8:44 am
According to the screenshots you put the libpack into the build directory. However, the variable FREECAD_LIBPACK_DIR points to the build directory but not inside the libpack directory.
enderelohim
Post by enderelohim » Sat Nov 14, 2020 1:27 pm
What should i do?
how to make it x64?
Site Admin
Post by wmayer » Sat Nov 14, 2020 1:51 pm
You must delete the cache and repeat configure.
enderelohim
Post by enderelohim » Sat Nov 14, 2020 1:59 pm
So i created a empty folder named "Build Target"
than i selected FreeCad 0.19_pre file for "where is the source code:"
than i selected empty folder "Build Target" for "where is build the binaries:"
Than i clicked Configure and waited for finish to get error.
Than i selected FREECAD_LIBPACK_DIR and target that to FreeCADLibs_12.1.4_x64_VC15
After select folder i clicked "Generate" and get "Error in configuration process, project filesq may be invalid"
And after that if i open Build Target folder this is what i see
And i recorded video for what i'm doing
https://youtu.be/nzz8YZ80zoU
enderelohim
Post by enderelohim » Sat Nov 14, 2020 3:09 pm
okay currently i fixed issues and get a sln.
