请问怎么在FC里测量一段曲线的长度?
Chinese forum
rujd
请问怎么在FC里测量一段曲线的长度?
Post by rujd » Mon May 11, 2020 2:30 am
比如一段弧的长度,或是一段螺旋线的长度,谢谢!
rujd
Re: 请问怎么在FC里测量一段曲线的长度?
Post by rujd » Mon May 11, 2020 3:17 am
再补充一问,如何测量曲线上任意两点之间沿曲线的距离?
fc_tofu
Post by fc_tofu » Mon May 11, 2020 6:31 am
You first install an addon named "Curves". Then,
1. in viewport, select curve you want to measure
2. In Curves toolbar, click "Info" tool. The length of curve and other info is displayed on topleft corner of viewport.
Curves Workbench
https://github.com/tomate44/CurvesWB
fc_tofu
Post by fc_tofu » Mon May 11, 2020 7:03 am
1. DraftWB, toggle on Snap bar >Near.
2. DraftWB >Line, draw a line between 2 arbitary points on your curve.
3. DraftWB >Trim, extend above line both ends beyond the curve.
4. PartWB, select both above line and curve, "Boolean Fragments", create a fragmented compound.
5. DraftWB >Downgrade, convert above compound into separate edges.
6. CurveWB >Join, combine needed edges into single curve.
7. CurveWB >Info, select above single curve in viewport.
length_of_curve_segment.FCStd
(15.62 KiB) Downloaded 111 times
paullee
Post by paullee » Mon May 11, 2020 12:56 pm
"英文化"了 :lol:
的確 比中文輸入快 :D
fc_tofu
Post by fc_tofu » Mon May 11, 2020 3:57 pm
"英文化"了 :lol:
CurvesWB是纯英文的工作台,命令名都是英文,所以就用英文回答了。 :D
rujd
Post by rujd » Tue May 12, 2020 10:45 am
"英文化"了 :lol:
非常感谢!虽然都是英文的。我要好好研究研究,另外0.19版的国内有镜像下载地址吗?
paullee
Post by paullee » Tue May 12, 2020 1:06 pm
leeon wrote:
Sun Jan 26, 2020 7:30 am
Ping
https://forum.freecadweb.org/posting.ph ... &p=363517
rujd
Post by rujd » Tue May 12, 2020 1:48 pm
Ping
谢谢!FC官网的0.19版有两个版本,之前我在QQ群里问win7 64位该下哪个,群友说是“FreeCAD_0.19.20996_x64_LP_12.1.2_PY3QT5-WinVS2015.7z
”这个,但是我看FreeCADweb.cn给出的0.19的win64位版,是那个win-conda版的,不知道这两个版本有什么区别?
rujd
Post by rujd » Tue May 12, 2020 1:52 pm
"英文化"了 :lol:
谢谢!我用0.19版下载curve工作台的的时候总是卡在这里。我不知道怎么上传图片,就截图放在附件里了,谢谢!
