LibPack for Windows "Python packages"
Re: LibPack for Windows "Python packages"
While a release build works, the debug build fails:
Creating library D:/FreeCAD-build/src/App/Debug/FreeCADApp_d.lib and object D:/FreeCAD-build/src/App/Debug/FreeCADApp_d.exp
58>PropertyContainerPyImp.obj : error LNK2001: unresolved external symbol __imp__Py_NegativeRefcount
58>PropertyFile.obj : error LNK2001: unresolved external symbol __imp__Py_NegativeRefcount
58>PropertyStandard.obj : error LNK2001: unresolved external symbol __imp__Py_NegativeRefcount
58>ExtensionContainerPyImp.obj : error LNK2001: unresolved external symbol __imp__Py_NegativeRefcount
58>DocumentObjectGroup.obj : error LNK2001: unresolved external symbol __imp__Py_NegativeRefcount
58>FeaturePython.obj : error LNK2001: unresolved external symbol __imp__Py_NegativeRefcount
58>ObjectIdentifier.obj : error LNK2001: unresolved external symbol __imp__Py_NegativeRefcount
58>Application.obj : error LNK2001: unresolved external symbol __imp__Py_RefTotal
58>ApplicationPy.obj : error LNK2001: unresolved external symbol __imp__Py_RefTotal
58>MaterialPyImp.obj : error LNK2001: unresolved external symbol __imp__Py_RefTotal
58>PropertyContainerPyImp.obj : error LNK2001: unresolved external symbol __imp__Py_RefTotal
58>PropertyFile.obj : error LNK2001: unresolved external symbol __imp__Py_RefTotal
58>PropertyLinks.obj : error LNK2001: unresolved external symbol __imp__Py_RefTotal
58>PropertyStandard.obj : error LNK2001: unresolved external symbol __imp__Py_RefTotal
58>DocumentPyImp.obj : error LNK2001: unresolved external symbol __imp__Py_RefTotal
58>FeaturePython.obj : error LNK2001: unresolved external symbol __imp__Py_RefTotal
58>LinkBaseExtensionPyImp.obj : error LNK2001: unresolved external symbol __imp__Py_RefTotal
58>ObjectIdentifier.obj : error LNK2001: unresolved external symbol __imp__Py_RefTotal
58>ExtensionContainerPyImp.obj : error LNK2001: unresolved external symbol __imp__Py_RefTotal
58>GroupExtensionPyImp.obj : error LNK2001: unresolved external symbol __imp__Py_RefTotal
58>DocumentObjectGroup.obj : error LNK2001: unresolved external symbol __imp__Py_RefTotal
58>DocumentObjectPyImp.obj : error LNK2001: unresolved external symbol __imp__Py_RefTotal
58>D:\FreeCAD-build\bin\FreeCADApp_d.dll : fatal error LNK1120: 2 unresolved externals
I googled around and found this workaround. I applied this solution: https://stackoverflow.com/questions/388 ... or-windows
to comment out
# define Py_DEBUG
-> I'll check if the problems vanishes if I use the Python that comes with the LibPack.
OK, I found the problem: the Python libraries were found by CMake but not the debug library. I see that we have these 2 properties in CMake:
PYTHON_LIBRARY_DEBUG
and
PYTHON_DEBUG_LIBRARY
(what's their difference?)
When running CMake (I have CMake 3.18.5) both are not found, I had to add for both manually the path to the LibPack:
D:/FreeCAD-build/FreeCADLibs_12.4.2_x64_VC17/bin/libs/python38_d.lib
then I can compile a debug build without modifying pyconfig.h.
However, when compiling a debug build, I get the info that 2 PDB's are missing:
freetyped.lib(ftinit.obj) : warning LNK4099: PDB 'freetype.pdb' was not found with 'freetyped.lib(ftinit.obj)' or at 'D:\FreeCAD-build\Mod\Part\freetype.pdb'; linking object as if no debug info
Qt5UiToolsd.lib(quiloader.obj) : warning LNK4099: PDB 'Qt5UiToolsd.pdb' was not found with 'Qt5UiToolsd.lib(quiloader.obj)' or at 'D:\FreeCAD-build\bin\Qt5UiToolsd.pdb'; linking object as if no debug info
There is a further issue:
When I use a2plus with my build I get this error:
Therefore I run
This gives me numpy 1.9.4 (and issues a warning that my pip version is outdated:
But the problem persists.
Importing the numpy C-extensions failed. This error can happen for
many reasons, often due to issues with your setup or how NumPy was
installed.
We have compiled some common reasons and troubleshooting tips at:
https://numpy.org/devdocs/user/troubleshooting-importerror.html
Please note and check the following:
* The Python version is: Python3.8 from "D:\FreeCAD-build\bin\FreeCAD_d.exe"
* The NumPy version is: "1.18.2"
and make sure that they are the versions you expect.
Please carefully study the documentation linked above for further help.
Original error was: No module named 'numpy.core._multiarray_umath'
" occurred in C:\Users\USti\AppData\Roaming\FreeCAD\Mod\A2plus\InitGui.py
pip install --upgrade numpy
WARNING: You are using pip version 20.2.1; however, version 20.3.1 is available.
You should consider upgrading via the 'c:\program files\python38\python.exe -m pip install --upgrade pip' command.
Updated the lib pack.
The warnings should now be gone...
https://github.com/apeltauer/FreeCAD/re ... ack_12.4.2
I use the Python bundles in your LibPack:
As I wrote, I had to fill the values for PYTHON_LIBRARY_DEBUG and PYTHON_DEBUG_LIBRARY manually since CMake did not fill it automatically.
Sorry for the misslead. I thougt that some how your local python is used because pip is telling this:
Indeed, this is the path of my local Python installation. I'll check out your new LibPack at the moment and if the problem persists, I will remove the local Python.apeltauer wrote: ↑Mon Dec 07, 2020 9:25 am Sorry for the misslead. I thougt that some how your local python is used because pip is telling this:).[/code]Code: Select all
