Replace the numpy in your build/install and it seems to work.
I'll next see if I can get the release and debug to work in the same Libpack.
EDIT: numpy.7z at the above link has release and debug numpy 0.19.4, they seem to peacefully coexist.
apeltauer wrote: ↑Fri Jan 08, 2021 7:36 am
I have updated the libpack...
Is it possible to update the release message with the date of the last libpack update? Also if I just unpack over the old 12.4.2 libpack should I run CMake configure/generate or building the previous solution will just work?
kisolre wrote: ↑Fri Jan 08, 2021 3:47 pm
I tried this and it is not working. You must unpack the libpack to its own folder. Then you must also recompile the whole FreeCAD from scratch, meaning to delete the CMake cache and set up everything (path etc.) new. At first I tried to avoid this and just adapted the paths in CMake to the new folder of the Libpack but I got compilation errors.
many thanks! (So the CMake fix is included?)
Can you please make an announcement like you did in this thread: https://forum.freecadweb.org/viewtopic.php?f=4&t=42945
I suggest to open a new thread for the announcement since the existing one is hard to read for newbies and one is only interested on the current LibPack not the past ones and their issues. I would also pin this new thread and unpin the existing.
uwestoehr wrote: ↑Fri Jan 08, 2021 5:45 pm
I moved the old version of the libpack to a backup directory and put this new one in the exact same old path (since it's got the same version number). Visual Studio didn't have a problem with it and relinked without any problems.
chennes wrote: ↑Fri Jan 08, 2021 6:03 pm
That is what I meant. I already use the 12.4.2 version and was wandering since it has changes but it is still 12.4.2 is this the way it is supposed to work - replace files in the already used 12.4.2 folder. Thanks for the replies.
