Improvement proposal for Link in conjunction with Body
openBrain
Post by openBrain »
Hi all,
I just remarked how Link behaves with Body. From my side the current behavior seems to be pretty unnatural and useless (not insulting in any way :P).
As a context, I'd like to use Link applied to Body in 2 different contexts :
  • Assembly : parts of an assembly are modeled with PartDesign one in a different file (so basically each part is a Body in its own file) and I have an assembly file where I want to link to each part
  • Sharing : when 2 parts have the same base shape, I model this latter in a file, then I want to link it to other files where specific operations are further added to the base to create each variant part
Improvement #1
First below is what happened currently if I set a Link to a Body :
It creates a duplicate of the Body with its complete tree items as Links.
What I'd expect (and thus propose) is that it creates a Link only to the Body container itself, with shape being the tip of the Body. Something similar to applying Draft/Clone or Part/RefinedCopy to the Body with the advantage it works across 2 files.
Improvement #2
Currently Link objects can't be used as BaseFeature in a Body. Below is how it looks like if you try with the error message in the tooltip.
I think it is really a pity and I'd like that it could be possible.
Improvement #3
It is currently possible to set a Link to an internal feature of a Body. The created is outside the Body but this is an allowed link (not out of scope). This can be great, but unfortunately ATM the shape orientation isn't kept (on the example, the Sketch is on XZ plane) :
I didn't see any usage of this feature for me, but I guess it would be better if orientation is correctly linked to too.
Here we are. What are your thoughts about all this ? Do you think these are really improvements ?
vocx
Re: Improvement proposal for Link in conjunction with Body
Post by vocx »
openBrain wrote: Wed Apr 01, 2020 1:07 pm ...
[*]Sharing : when 2 parts have the same base shape, I model this latter in a file, then I want to link it to other files where specific operations are further added to the base to create each variant part[/list]
This has already been discussed a couple of times in the forum.
The general notion is that, yes, realthunder will add more support for App Link and PartDesign Bodies in the future. The reason this hasn't happened yet is because the changes are a bit difficult to implement, so he needs to do some more testing to see what works the best.
Re: App::link of sketch in PD Body
Why Link should be available in PartDesign
Improvement #1
What I'd expect (and thus propose) is that it creates a Link only to the Body container itself, with shape being the tip of the Body...
Probably this is exactly what is occurring under the hood. I mean, how does it affect you to display all items under the Body?
Improvement #2
I think this is the same discussion as the previous two threads. It will come, realthunder just needs to do the work and be sure it won't break everything.
So far it's been discussed to link the base sketches to have a "library" of profiles that can be modified quickly. Or using partial solids inside other solids, precisely like a BaseFeature. Or Zolko's idea of using variant "Links", which is a linked object that could still be modified a little with certain parameters.
Also, just because you can't use the BaseFeature it's not a big problem as you surely can use the new PartDesign SubShapeBinder.
Improvement #3
It sounds like you could use PartDesign SubShapeBinder.
Also, I think you repeated the same image twice.
openBrain
Post by openBrain »
vocx wrote: Wed Apr 01, 2020 5:47 pm Probably this is exactly what is occurring under the hood. I mean, how does it affect you to display all items under the Body?
  1. This isn't what I expect :) And actually I don't see any added value to this.
  2. This clutters a lot the tree if eg. I just want to use this Body into an assembly
  3. If I activate the linked Body and add a sketch in it (let say I want to further operate this link), it actually adds it as a link and the "real" sketch is created in the original Body. Which again I don't think is useful in real modeling.
:shock: A SubShapeBinder doesn't bring any real solid material. The goal of the BaseFeature is aptly to use it as a base solid for further processing.
Right. Fixed. Makes more sense now. ;)
adrianinsaval
Post by adrianinsaval »
openBrain wrote: Wed Apr 01, 2020 6:00 pm
You could simply collapse the body so it doesn't clutter, the added value is that you can edit the linked object right there, no need to open in a separate tab, and you can see how it was constructed and every other detail. Your third point is exactly the behavior I and probably many more people expect, if you're editing the linked body its reasonable that the modifications be applied to the original file.
Now that isn't to say that a link with only the shape is not useful, that is what subshapebinders are for, and guess what: you can use them as basefeature! See attached example(download both files in same folder and open test2.FCStd). I think this is what you want.
test2.FCStd
(12.76 KiB) Downloaded 20 times
test.FCStd
(7.36 KiB) Downloaded 20 times
openBrain
Post by openBrain »
adrianinsaval wrote: Wed Apr 01, 2020 6:49 pm You could simply collapse the body so it doesn't clutter, the added value is that you can edit the linked object right there, no need to open in a separate tab, and you can see how it was constructed and every other detail. Your third point is exactly the behavior I and probably many more people expect, if you're editing the linked body its reasonable that the modifications be applied to the original file.
Why not ? Let's say have an option so that the Link can be some kind of either 'Tip' (exposed as a simple object) or 'Through' (exposed with its tree). But IMO it could also be a reasonable solution that a Body always link as a simple object and when you double-click on it, it automatically opens the source. ;)
It almost work. The binder isn't correctly restored when I open the file so basically it's broken. Apart of that, this is just an horrible solution. :)
adrianinsaval
openBrain wrote: Wed Apr 01, 2020 7:04 pm Why not ? Let's say have an option so that the Link can be some kind of either 'Tip' (exposed as a simple object) or 'Through' (exposed with its tree). But IMO it could also be a reasonable solution that a Body always link as a simple object and when you double-click on it, it automatically opens the source. ;)
I wouldn't want that to be default, it is easier to edit right there and easier to reference parameters from within the body in some expression I may use. Having to open the file separately for all that would be annoying. EDIT: I'm not against having the option though, maybe there is one already and its burried in the sea of the forum unbeknownst to us.
Not broken for me, I even edited test separately and only required a recompute to update the link when I opened test2. Did you download both files in the same folder with the same names? What version of FreeCAD are you using? EDIT: also what error did you get?
Why is it horrible? Whats the benefit of showing only the body and having acces only to its shape over a subshapebinder?
adrianinsaval
openBrain wrote: Wed Apr 01, 2020 1:07 pm Improvement #2
Realthunder has this implemented in his fork: https://github.com/realthunder/FreeCAD_ ... Notes-0.11
forum post: https://forum.freecadweb.org/viewtopic. ... 42#p391176
It may be merged in 0.20
Edit: basefeature doesn't support the multiple solids from a body that can be used in realthunders branch, not sure of the relevance of this but I reported it anyway: https://github.com/realthunder/FreeCAD/issues/29
openBrain
Post by openBrain »
adrianinsaval wrote: Fri Apr 24, 2020 7:38 pm Realthunder has this implemented in his fork: https://github.com/realthunder/FreeCAD_ ... Notes-0.11
Good to know. Thx. :+1:
