Assembly Workbench icons aligned to guidelines
Moderator: agryson
Re: Assembly Workbench icons aligned to guidelines
You're welcome. I guess what we now need is a bit more useful Assembly workbench.agryson wrote:Done.
Thanks for the tip on implementation @triplus
This can now be in the pull request. (tested sucessfully on local)
AssemblyWorkbench.svg
P.S. Or maybe after you finish all the work you might give it a shot at aligning Assembly 2 workbench icons. As that is more or less what FreeCAD users have been using in the past years when it comes to Assembly capabilities. Note that this is just an idea and feel free to disregard it.
sounds good, and I'm sure that many of the icons could be reused between the two during development of FreeCAD Assembly. added to the listtriplus wrote:maybe after you finish all the work you might give it a shot at aligning Assembly 2 workbench icons. As that is more or less what FreeCAD users have been using in the past years
