Polishing of draft wb
Moderator: agryson
HoWil
Re: Polishing of draft wb
Post by HoWil » Fri Mar 31, 2017 5:58 pm
yorik wrote: But if more people want the draft default color to be white, of course, I have nothing against changing.
I my opinion it is not only switching to white. It is almost more on emphasizing hints in color like the points or the snapping suggestions. Additionally, it would be great if they could be drawn larger as in my suggestion above.
BR
Howil
kkremitzki
Post by kkremitzki » Fri Mar 31, 2017 7:25 pm
BR
Howil
+1
Post by yorik » Mon Apr 10, 2017 9:16 pm
kkremitzki wrote:Additionally, it would be great if they could be drawn larger as in my suggestion above.
Unfortunately they are drawn with SoMarkerSet nodes and they are already at maximum size (9). This would require to make custom coin nodes, that's much more work. But I'll keep it in a corner of my mind...
Post by wmayer » Tue Apr 11, 2017 8:36 am
SoMarkerSet can be extended with custom bitmaps:
https://grey.colorado.edu/coin3d/classS ... 08d6c233a4
However, I have no clue if you get it working via its Python interface using pivy. At least it works using C++ which we also did to get bigger circles in the sketcher module
looo
Post by looo » Tue Apr 11, 2017 9:27 am
wmayer wrote:However, I have no clue if you get it working via its Python interface using pivy. At least it works using C++ which we also did to get bigger circles in the sketcher module
I don't think it's working right now, but it shouldn't be much work:
NotImplementedError: Wrong number or type of arguments for overloaded function 'SoMarkerSet_addMarker'.
  Possible C/C++ prototypes are:
    SoMarkerSet::addMarker(int,SbVec2s const &,unsigned char const *,SbBool,SbBool)
    SoMarkerSet::addMarker(int,SbVec2s const &,unsigned char const *,SbBool)
    SoMarkerSet::addMarker(int,SbVec2s const &,unsigned char const *)
maybe direct conversation from svg to unsigned char is possible?
minimalistic blog: https://looooo.github.io/mini-blog/
looo
Post by looo » Tue Apr 11, 2017 2:05 pm
I have tried to implement the addMarker function in pivy:
implementation, example
There seems to be some problems with the boarders of the bitmap. Some empty columns are necessary to get a good visualization of the bitmap.This is also true for the c++ implementation http://github.com/FreeCAD/FreeCAD/blob/ ... cpp#L64L75
Post by wmayer » Tue Apr 11, 2017 2:59 pm
    SoMarkerSet.CUSTOM_BIT_MAP_1 = 99
    SoMarkerSet.CUSTOM_BIT_MAP_2 = 98
You don't have to deal with hard-coded numbers. With
idx = SoMarkerSet.getNumDefinedMarkers()
you get the next index for a new bitmap which you then can add with
SoMarkerSet.addMarker(idx, SbVec2s(width, height), bitmap);
looo
Post by looo » Tue Apr 11, 2017 3:51 pm
thanks for the hint.
Automatic rendering of a svg-file seems to be a bit more complecated with python. (at least I didn't succeed with PySide) Maybe this could be done in FreeCADGui? Something like this:
FreeCADGui.svg2string(file-path, scale) -> returns char * / bytes.
This way all markers could have the same source (svg) but have different scale (regarding screen size, or user preference)
Post by wmayer » Tue Apr 11, 2017 4:53 pm
To convert a svg icon into a format Coin3d will understand you can try this:
from PySide import QtCore
from PySide import QtGui
icon=QtGui.QBitmap(QtGui.QPixmap(":/icons/delete.svg"))
buffer=QtCore.QBuffer()
buffer.open(buffer.WriteOnly)
icon.save(buffer,"XPM")
buffer.close()
ary=buffer.buffer()
lines=ary.split(",")
ba=QtCore.QByteArray()
for i in lines[3:]:
   ba = ba.append(i)
ba=ba.replace("#","x")
ba=ba.replace("."," ")
ba.data()
looo
Post by looo » Tue Apr 11, 2017 7:38 pm
thanks, added: https://github.com/looooo/pivy/blob/mas ... y/utils.py
with the last two arguments of SoMarkerSet::addMarker(..., isLSBFirst, isUpToDown) both set to false the full bitmap is shown without the need of an additional empty first column...
example how to use this feature: https://github.com/looooo/pivy/blob/mas ... svg.py#L36
