UI/UX suggestions for Addon Installer
Re: UI/UX suggestions for Addon Installer
Post by yorik »
Kunda1 wrote: Thu Aug 02, 2018 2:13 pm mario52 wrote: ↑
02 Aug 2018, 06:19
i add one button execute (edit the macro in FreeCAD and execute)
Great job! What does the community think?
+1
Mario's template is now supported by the addon manager as of git commit 53c2058e0
Post by Kunda1 »
How do these dimensions looks like to everyone ?
Changed code from:
        #self.resize(326, 304)
        self.resize(626, 404)
Post by yorik »
+1
Post by Kunda1 »
yorik wrote: Thu Aug 02, 2018 8:01 pm+1
https://github.com/FreeCAD/FreeCAD/pull/1582
Quick question:
what's the reason why the AddonManager doesn't have a .ui file instead of the dialog being generated from the .py file ?
Post by yorik »
Kunda1 wrote: Fri Aug 03, 2018 12:47 pmwhat's the reason why the AddonManager doesn't have a .ui file instead of the dialog being generated from the .py file ?
Because it started as a simple macro, so it was easier to have it all embedded in the same file. Now it could become a separate ui file, though...
Post by Kunda1 »
yorik wrote: Fri Aug 03, 2018 1:52 pm
Oh, I see! Makes sense. kkremitzki was working on a .ui file.. I wonder if I could use that or even borrow the QGIS .ui (and remove a lot of the bells and whistles).
@yorik BTW, thanks for the PR merge!
Post by Kunda1 »
kkremitzki wrote:ping
Hey man, where is that .ui file you were working on for the Addon Installer. Did you attach it to a post somewhere ?
yorik wrote:ping
How do I render out a .ui file from the python file that runs AddonManager ?
Post by Kunda1 »
Revisiting this thread.
Addon Manager is getting a lot more attention lately and the FreeCAD-addon repo along with the FreeCAD-macros repo are both growing. Which means the option list is growing. So there may be merit to revisit the idea of augmenting the UI of the addon manager.
Post by yorik »
We really need to redo it indeed. And integrate a bit more description of the addon (basically we need to fetch the whole readme, I think).
I'll also try to do a little mockup this week...
Kunda1 wrote: Thu Sep 06, 2018 8:31 pm How do I render out a .ui file from the python file that runs AddonManager ?
Showing an ui file is easy:
import FreeCADGui
mydialog = FreeCADGui.PySideUic.loadUi("/path/to/my/dialog.ui")
mydialog.show()
But the real work is to write and tie the code behind each button and control... In the case of the Addon manager, most of it is there already, but it would still need some work to adapt.
