Alternative GUI for FreeCAD: Overlayed Layout (Devs needed)
Moderator: agryson
Re: Alternative GUI for FreeCAD: Overlayed Layout (Devs needed)
Post by Kunda1 » Mon Nov 26, 2018 2:09 pm
@triplus has released Glass WB which adds a transparency to the sidebars now. It's far from @ickby's achievement but nevertheless a strong step in the right direction.
Post by Kunda1 » Wed Jan 09, 2019 5:41 pm
Obligatory new years 'bump' to this post. :D
regis
Post by regis » Thu Jan 10, 2019 4:33 am
Totally agree. Can this be done in python aswell?
ickby
Post by ickby » Fri Jan 11, 2019 7:15 am
The way I did implement it not, it needed some changes in the c++ code. However, triplus did some good work which back then was not possible with qt4. So I have no clue how far he can get. Maybe now it is possible to achieve all I did with python only, just in annother way of implementing it.
regis
Post by regis » Mon Jan 14, 2019 5:19 pm
Ok is there some type of visual software that allows you to create such user interface graphically instead of programmatically?
Post by yorik » Mon Jan 14, 2019 9:29 pm
QDesigner (on windows I think it's part of QCreator, on linux you can get it standalone)
ickby
Post by ickby » Tue Jan 15, 2019 11:50 am
I used qt's QML language to build the UI, except of curse the panels, wich have been the default freecad ones. But the layout engine, the dragging etc, was done in qml:
http://doc.qt.io/qtcreator/creator-usin ... igner.html
regis
Post by regis » Wed Jan 16, 2019 12:41 am
thanks all,
first look at qt designer, lots of botton to figure out, hehe :D :D
Screenshot from 2019-01-15 19-40-05.png (123.85 KiB) Viewed 650 times
Post by yorik » Wed Jan 16, 2019 1:31 pm
Bascially you create a new widget or dialog (dialogs are meant to be standalone, while widgets are meant to be inserted in another panel), then you add controls to it (push buttons, texts or images (labels), line edit fields, etc...). You have several tools like groups, layouts and separators to help organize things better.
So for example you would want to create a new window tool. You would think of what information the user needs to provide, then you would create a dialog that makes it clear for the user how to proceed.
The next step is to make the code that gets executed when the user presses buttons, etc... But that's for later.
regis
Post by regis » Wed Jan 30, 2019 5:59 pm
Thanks for the startup tip, Does it allow me to create these kinds of windows aswell?
Screenshot from 2019-01-30 12-59-04.png (14.17 KiB) Viewed 519 times
Screenshot from 2019-01-29 21-13-56.png (109.67 KiB) Viewed 519 times
Screenshot from 2019-01-29 21-06-51.png (63.28 KiB) Viewed 519 times
