[BUG?] Cropped icons
bill
Re: [BUG?] Cropped icons
Post by bill »
Were you aware of this problem: https://forum.freecadweb.org/viewtopic. ... 0&start=20
:idea:
I have since come to realize that the problem TOGGLES between Daily and 17 depending on where you set the styles last; even though they are displayed. :?
pablogil
Post by pablogil »
bill wrote: Thu May 24, 2018 12:01 pm Were you aware of this problem: https://forum.freecadweb.org/viewtopic. ... 0&start=20
:idea:
Hi bill,
No, I wasn't aware of this problem but it seems like it's not the stylesheet but the config file... doesn't it?
triplus
Post by triplus »
I looked in the code and to be honest i don't see anything special or obvious on why File and View toolbars should behave any different. What about the Macro toolbar. Does it work as expected? Once the issue occurs if you look under the File -> New and View -> Standard views global menu entries. Are the icons normal there?
pablogil
Post by pablogil »
triplus wrote: Mon Jun 11, 2018 7:43 am I looked in the code and to be honest i don't see anything special or obvious on why File and View toolbars should behave any different. What about the Macro toolbar. Does it work as expected? Once the issue occurs if you look under the File -> New and View -> Standard views global menu entries. Are the icons normal there?
Sorry, I missed this post...
Yes, you are right, it also happens with the Macro toolbar. I haven't report about it because I always have it disabled...
Here is what I get:
Any clue then?
Thanks
triplus
Post by triplus »
pablogil wrote: Fri Jun 15, 2018 3:34 pm Any clue then?
Thanks
Thanks for the feedback. One thing i am still wondering about. Once the issue occurs. If you take a look under (global) menu View -> Standard views. Are the view related icons OK or resized?
pablogil
Post by pablogil »
triplus wrote: Mon Jun 18, 2018 9:12 am
Thanks
They are OK:
triplus
Post by triplus »
Thanks for the info. It helps narrowing down the potential places on where to look for clues. Will take another look in the following days and hopefully something will stand out.
triplus
Post by triplus »
Note that i didn't forget about this issue. It's just i didn't find anything obvious, and due to not having such display setup, no real testing could be done:
https://forum.freecadweb.org/viewtopic. ... 37#p275369
While answering the other question, i realized, i might not need a macOS and external retina display at all. Maybe similar issue will be reproducible on Linux and on two screens having different resolutions. Will try to test this use case over the weekend and report back.
triplus
Post by triplus »
OK i was able to reproduce the issue on Linux, when using two displays, each having different (Qt) scale factor set. The problem is related to icons loaded from the icon theme. Such icons are scaled up to the display using the biggest scale factor, and don't adapt after anymore. In the following days i will do more testing, independently of FreeCAD, to first confirm this is a Qt related issue. Once that gets confirmed, and as the next version of IconThemes module will use such icon theme approach, i will likely report this issue to the upstream Qt devs. Hopefully they will be prepared to fix it.
For now this is what you can do to remove the issue. Copy paste the snippet in FreeCAD Python console:
p = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Bitmaps/Theme")
p.SetString("Name", "None")
After FreeCAD gets restarted the issue with the icons should be resolved.
To revert to defaults:
p.RemString("Name")
triplus
Post by triplus »
Hi @pablogil
Can you confirm this is still an issue, when using latest FreeCAD 0.19 DMG?
