Building Libs for Windows Debug Version with VS2017/Qt5.12
sgrogan
Re: Building Libs for Windows Debug Version with VS2017/Qt5.12
Post by sgrogan » Mon Apr 01, 2019 11:06 pm
Un-checking USE_SUPERBUILD seems to be the key.
After this I'm able to set the paths to the LibPack(also see the un-grouped entries). It also seems that netgen is using the occ strategy of using a directory structure to distinguish debug vs release builds, not file name. This is a PITA, but I think both wmayer and peterl94 have provided workarounds for this with occ, maybe we can use them for netgen as well?
When building the nglib project I get this
1>------ Build started: Project: nglib, Configuration: Release x64 ------
1>nglib.cpp
1>c:\users\chris\github\netgen\libsrc\occ\occgeom.hpp(275): error C2679: binary '<<': no operator found which takes a right-hand operand of type 'overloaded-function' (or there is no acceptable conversion)
1>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\include\ostream(508): note: could be 'std::basic_ostream<char,std::char_traits<char>> &std::basic_ostream<char,std::char_traits<char>>::operator <<(std::basic_streambuf<char,std::char_traits<char>> *)'
Maybe an OCC 7.3 porting issue?
apeltauer
Post by apeltauer » Tue Apr 02, 2019 5:03 am
1>nglib.cpp
I had the same error, for me it was resolved by replacing "endl" with "std::endl"...
apeltauer
Post by apeltauer » Tue Apr 02, 2019 8:09 am
Update: nearly done.... FEM can be compiled and run in debug mode....
The release version i am working on. Then i will update the libpacks again....
apeltauer
Post by apeltauer » Tue Apr 02, 2019 11:51 am
FEM is now running..... :o :o :o
I was able to build netgen with opencascade from the the libpack, for the debug libs and release libs, see the dependey walker
Next step is to remove all absolute paths in the cmake files....
sgrogan
Post by sgrogan » Wed Apr 03, 2019 10:25 pm
apeltauer wrote:
Tue Apr 02, 2019 2:51 pm
Updated the libpack (https://github.com/apeltauer/FreeCAD/re ... bPack_12.1)
Thanks!
What Version of CMake are you using? I have a version.h problem in dxf.cpp I don't think it's related to your libpack, but rather to my new CMake(3.14.1)
With this version of your libpack and my new cmake my previous problems finding boost are gone, but now cmake can't find matplotlib, I'm tracking this down.
How did you handle numpy? I want to test a pip installed scipy to ensure compatibility.
Would you consider adding git-python? It's not a hard dependency, but it adds functionality to the addons-manager. I can handle this at packaging if your not interested. pyyaml, same thing except it's only used by some addon wb's.
How do you run FreeCAD after compilation? from VS? I need to move some files around to use "copy the contents of the bin directory of the libpack to the bin directory of the build directory".
I also have some NetgenPlugin errors that should be fixed by your pull request. I'll fetch your code and test this if it isn't merged into master first.
Awesome work, I don't know how to say thanks enough. :D
Post by wmayer » Thu Apr 04, 2019 8:02 am
On my system I have several libpacks built for different compiler versions. In order to save some disk memory I don't copy the dlls into the bin directory but use a .bat file to start FreeCAD.
A typical .bat file looks like this:
set PATH=PATH_TO_THE_LIBPACK\bin;%PATH%
start FreeCAD.exe --write-log %1 %2 %3
I stopped using Visual Studio some years ago and switched to QtCreator as IDE but IIRC you can also define a .bat file as program in Visual Studio.
apeltauer
Post by apeltauer » Thu Apr 04, 2019 9:12 am
At the moment I am using cmake version 3.14.0.
Right now Numpy is only working with the Python.exe (release version). I have not figured out how to get the debug version for python_d.exe. I searched the internet, but just found out that Numpy has some problems to have the release and the debug version parallel installed....
No problem, I am adding git-python and pyyaml. Any other python libs??
I copy the FreeCADLibs_12.1.2_x64_VC15_bin_debug.7z or FreeCADLibs_12.1.2_x64_VC15_bin_release.7z files next to my bin folder. But like Werner already mentioned you could also extend your path variable and then run FreeCAD. To debug FC i run it through vs debugger....
BTW: Since yesterday I am using Visual Studio 2019. VS 2015,2017 and 2019 share the same runtime, so we can use the libpack with all this versions.... But the compile time was not reduced. To bad that VS2013 was quite faster then 2017 and 2019... :(
apeltauer
Post by apeltauer » Thu Apr 04, 2019 1:04 pm
Updated the libpack with the additional python libs.... (https://github.com/apeltauer/FreeCAD/re ... bPack_12.1)
Post by wmayer » Fri Apr 05, 2019 12:21 pm
Many thanks! With the new libpack everything works now out-of-the-box.
