Multiple Task dialogs simultaneously
JiriVALASEK
Post by JiriVALASEK » Fri Jun 21, 2019 10:24 pm
is it possible to have multiple task dialogs active simultaneously? I have multiple FeaturePythons and I'd like to open task dialogs for some of them, tinker with some parameters and save them. Nevertheless, when I do
dg = TaskDialog()
FreeCADGui.Control.showDialog(dg)
for my second FeaturePython, I get
<class 'RuntimeError'>: Active task dialog found
Thanks a lot.
Re: Multiple Task dialogs simultaneously
Post by chrisb » Sat Jun 22, 2019 12:34 am
No.
wandererfan
Post by wandererfan » Sat Jun 22, 2019 1:09 am
You can't have multiple task dialogs, but you can show a QDialog from within a task dialog.
Post by wmayer » Sat Jun 22, 2019 8:23 am
You can have only one TaskDialog at a time but a task dialog can have multiple task boxes. As an example to see how this looks create a sketch in PartDesign and edit it. On the left side you will see several boxes.
JiriVALASEK
Post by JiriVALASEK » Sat Jun 22, 2019 8:32 am
Yes, that's what I need. I wrongly assumed that what I see during sketching (img below) is multiple task dialogs. I haven't noticed there's only one StandartButton.
Could you nudge me in a direction how to do that?
Is there a way how to access currently opened task dialog (I can't find anything useful to do so in FreeCAD/src/Gui/Control.h)?
Thanks
Post by wmayer » Sat Jun 22, 2019 10:58 am
This is a trivial example:
from PySide2 import QtWidgets
class TaskDialog():
    def __init__(self):
        self.form=[QtWidgets.QCalendarWidget(),QtWidgets.QCalendarWidget(),QtWidgets.QCalendarWidget()]
FreeCADGui.Control.showDialog(TaskDialog())
So, the whole magic is that you define an attribute "form" that is a list of widgets.
JiriVALASEK
Post by JiriVALASEK » Sat Jun 22, 2019 11:04 am
class TaskDialog():
    def __init__(self):
I see. Thanks!
Btw. Is there a way to retrieve currently open TaskDialog (through Gui.Control or using another way)?
Post by wmayer » Sat Jun 22, 2019 12:29 pm
No, there isn't.
TheMarkster
Post by TheMarkster » Wed Jun 26, 2019 12:16 am
dg = TaskDialog()
Thanks a lot.
What about adding another tab? There is a code example on the wiki for doing it.
https://www.freecadweb.org/wiki/Code_snippets
(I think you need to replace qApp with QApplication in the example.)
