ezzieyguywuf
Post
by ezzieyguywuf » Wed Dec 04, 2019 5:55 pm
Latest PR closed.
PR 2751.
Leaving that link here as a reference, as the script used may be helpful to people in the future.
wmayer wrote: ↑Wed Dec 04, 2019 9:36 am
git blame has the option -w
This is absolutely the best way to approach this problem: nicely done wmayer!
sgrogan
Post
by sgrogan » Wed Dec 04, 2019 11:46 pm
ezzieyguywuf wrote: ↑Wed Dec 04, 2019 5:55 pm
Does anyone know what the github webgui uses? Or if can be configured to use the -w switch?
"fight the good fight"
- Site Admin
Post
by wmayer » Thu Dec 05, 2019 3:12 am
sgrogan wrote: ↑Wed Dec 04, 2019 11:46 pm
I wonder about this too as that's the way I most often use to check changes.
ezzieyguywuf
Post
by ezzieyguywuf » Thu Dec 05, 2019 11:16 am
- 5C3A6409-C5FD-44B1-ACEB-A6E2EEBF7D48.png (245.29 KiB) Viewed 792 times
Looks like it does not use the “-w”, though I’m not sure if it’s configurable.
here is a link
- Site Admin
Post
by wmayer » Thu Dec 05, 2019 12:04 pm
I found the answer here:
https://stackoverflow.com/questions/444 ... -on-github
To test:
A while ago I had one of these commits that changed the line-endings of a file
git commit 71dae0e63
When you look at the changes then the file src/Mod/Import/Gui/AppImportGuiPy.cpp has many whitespace changes. If you follow the solution and add ?w=1 at the end of the url you will see that only a few lines have actually changed in that file.
ezzieyguywuf
Post
by ezzieyguywuf » Thu Dec 05, 2019 3:09 pm
wmayer wrote: ↑Thu Dec 05, 2019 12:04 pm
@wmayer you’re on fire!
Edit:
Didn’t work for me for the blame link I posted above, on my phone...
- Site Admin
Post
by wmayer » Thu Dec 05, 2019 3:58 pm
ezzieyguywuf wrote: ↑Thu Dec 05, 2019 3:09 pm
Edit:
Yes, this is true but when I go to your FEM branch and look at the changes of the first commit then all files are modified. When adding the suffix it shows for every file
whitespace-only change
https://github.com/FreeCAD/FreeCAD/pull ... 80e708?w=1
Post
by Kunda1 » Fri Dec 06, 2019 7:47 am
This is a valuable gem. Nice!
Post
by bernd » Fri Dec 06, 2019 7:58 am
https://github.com/FreeCAD/FreeCAD/pull/2757
some informations. I had trouble on interactive rebases if adding the gitattribute file and the normalizing is in sparate commits. Thus I put it into one commit. The PR as it is now is how I would like to merge it into master.
IMHO, After the merge we should wait some time how does it work out until we do think about further changes in this regard.
