PR 2730, "Fix" line-endings
ezzieyguywuf
Re: PR 2730, "Fix" line-endings
Post by ezzieyguywuf » Wed Dec 04, 2019 5:55 pm
Latest PR closed. PR 2751.
Leaving that link here as a reference, as the script used may be helpful to people in the future.
wmayer wrote:
Wed Dec 04, 2019 9:36 am
git blame has the option -w
This is absolutely the best way to approach this problem: nicely done wmayer!
sgrogan
Post by sgrogan » Wed Dec 04, 2019 11:46 pm
Does anyone know what the github webgui uses? Or if can be configured to use the -w switch?
"fight the good fight"
Post by wmayer » Thu Dec 05, 2019 3:12 am
I wonder about this too as that's the way I most often use to check changes.
ezzieyguywuf
Post by ezzieyguywuf » Thu Dec 05, 2019 11:16 am
Looks like it does not use the “-w”, though I’m not sure if it’s configurable.
here is a link
Post by wmayer » Thu Dec 05, 2019 12:04 pm
I found the answer here: https://stackoverflow.com/questions/444 ... -on-github
To test:
A while ago I had one of these commits that changed the line-endings of a file git commit 71dae0e63
When you look at the changes then the file src/Mod/Import/Gui/AppImportGuiPy.cpp has many whitespace changes. If you follow the solution and add ?w=1 at the end of the url you will see that only a few lines have actually changed in that file.
ezzieyguywuf
Post by ezzieyguywuf » Thu Dec 05, 2019 3:09 pm
@wmayer you’re on fire!
Edit:
Didn’t work for me for the blame link I posted above, on my phone...
Post by wmayer » Thu Dec 05, 2019 3:58 pm
Edit:
Yes, this is true but when I go to your FEM branch and look at the changes of the first commit then all files are modified. When adding the suffix it shows for every file whitespace-only change
https://github.com/FreeCAD/FreeCAD/pull ... 80e708?w=1
Post by bernd » Fri Dec 06, 2019 7:03 am
get rid of line ending diffs in github by adding
?w=1
at the end of the address is a very value finding :D
https://github.com/FreeCAD/FreeCAD/commit/14eb6869a9
vs.
https://github.com/FreeCAD/FreeCAD/comm ... 6869a9?w=1
Post by Kunda1 » Fri Dec 06, 2019 7:47 am
wmayer wrote: ?w=1
vs.
This is a valuable gem. Nice!
Post by bernd » Fri Dec 06, 2019 7:58 am
https://github.com/FreeCAD/FreeCAD/pull/2757
some informations. I had trouble on interactive rebases if adding the gitattribute file and the normalizing is in sparate commits. Thus I put it into one commit. The PR as it is now is how I would like to merge it into master.
IMHO, After the merge we should wait some time how does it work out until we do think about further changes in this regard.
