[solved] hisa not found
Moderator: oliveroxtoby
peterko
Post by peterko »
I have a error running an analysis. Does anyone know how to solve? Maybe it has to do with hisa not being found.
The report view is attached.
ReportView.txt
(10.27 KiB) Downloaded 48 times
Python console says:
Python 3.6.6 | packaged by conda-forge | (default, Jul 26 2018, 11:48:23) [MSC v.1900 64 bit (AMD64)] on win32
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> MRU="0"
>>> exec(open('C:/Program Files/FreeCAD 0.18/data/Mod/Start/StartPage/LoadMRU.py').read())
>>> App.setActiveDocument("_020cfd_test")
>>> App.ActiveDocument=App.getDocument("_020cfd_test")
>>> Gui.ActiveDocument=Gui.getDocument("_020cfd_test")
>>> Gui.activateWorkbench("CfdOFWorkbench")
>>> import CfdCaseWriterFoam
>>> writer = CfdCaseWriterFoam.CfdCaseWriterFoam(FreeCAD.ActiveDocument.CfdAnalysis)
>>> writer.writeCase()
I think it has to do with hisa not being found. It reports a proper install, but when checking the dependencies I get:
Output:
Checking dependencies...
HiSA not found
Report view also attached.
ReportView depency check.txt
(2.93 KiB) Downloaded 39 times
About
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Re: hisa not found
Post by Kunda1 »
Install v0.19 and try again
peterko
Re: hisa not found
Post by peterko »
Thanks for your reply Kunda1. I have installed 0.19 on top of 0.18, assuming this is the way to do it.
Running the solver I still get the error:
Report view:
--> FOAM FATAL ERROR:
Cannot read file "constant/triSurface/.stl" or file "constant/triSurface/.stl.gz"
    From static int Foam::fileFormats::STLCore::detectBinaryHeader(const Foam::fileName&)
    in file stl/STLCore.C at line 109.
FOAM exiting
Running the dependency checker I still get: "HiSA not found".
Other suggestions?
oliveroxtoby
Re: hisa not found
Post by oliveroxtoby »
peterko wrote: Thu Oct 15, 2020 3:00 pm
Output:
HiSA not found
There must have been a problem with the hisa installation. Could you supply the full output of that process from the report view?
peterko
Re: hisa not found
Post by peterko »
Of course. I have attached it.
ReportViewHisaInstall.txt
(84.95 KiB) Downloaded 47 times
oliveroxtoby
Re: hisa not found
peterko wrote: Fri Oct 16, 2020 3:46 pm Of course. I have attached it.
Ah...g++ internal error. I remember encountering this when trying to build with multiple processors in the Docker container. I thought it was sufficient to limit the build to four processes, but your experience would suggest this doesn't always work. I have therefore limited the build on Docker to only occur in series. Please could you report back on whether this solves your problem.
peterko
Re: hisa not found
Post by peterko »
I first tried to set the solver to one core. This didn't solve the issue.
Then I installed the new freecad 0.19 version and run the solver. Still not solved. See reportview:
ReportView0_19OneCore.txt
(6.74 KiB) Downloaded 34 times
I don't fully understand:
"NOTE: The Conda Win based build are packaged from here: https://github.com/FreeCAD/FreeCAD-AppImage
They should be the Windows equivalent of the Conda based .AppImage and .dmg"
Am I doing something wrong during installation/unpackaging?
oliveroxtoby
Re: hisa not found
peterko wrote: Mon Oct 19, 2020 11:10 am I first tried to set the solver to one core. This didn't solve the issue.
The issue is not the number of cores used during the solve, but the number used during the build of HiSA. I have changed this to only use one process in the Windows Docker installation. To test this, you would first need to update the CfdOF workbench using the addon manager, restart FreeCAD and then re-do the 'Install HiSA' step from the CfdOF properties page. It should not matter which version of FreeCAD you are using.
peterko
Re: hisa not found
Post by peterko »
Thanks Oliver, for looking into this.
Unfortunately the hisa install still doesn't work. I first tried to reinstall hisa in freecad 0.18, which I kept installed. But in the addon manager only one workbench was left (3d prototype), while I expected to find the cfdof workbench here to update.
So I opened freecad 0.19. Here the workbench could be updated.
See the reportviews of three hisa install attempts attached.
ReportViewHisaInstallOneCore.txt
(53.39 KiB) Downloaded 36 times
ReportViewHisaInstall20201020.txt
(113.29 KiB) Downloaded 37 times
Once I tried with a terminal open, since I thought that this might be necessary:
ReportViewHisaInstallOneCoreOFterminal.txt
(49.46 KiB) Downloaded 37 times
oliveroxtoby
Re: hisa not found
peterko wrote: Tue Oct 20, 2020 2:41 pm Thanks Oliver, for looking into this.
ReportViewHisaInstallOneCore.txtReportViewHisaInstall20201020.txt
My mistake - please try updating CfdOF again.
