Hi Folks,
Can someone point me in the correct direction on how to "Import Tool Table" please.
I have a LinuxCNC tool table (.tbl) that as I understand should be importable.
Thanks, X
Import Tool Table
- sliptonic
Re: Import Tool Table
It's not possible to directly import a linuxcnc tool table yet. Only importers for XML and Heekscnc's format have been written.
It should be pretty easy to write a handler for linuxcnc and would be gratefully accepted. Everything should be in the file /Mod/Path/PathScripts/ToolTableEditor.py
Thanks for the response.
As I've shared in the past, I'm the last person you would want tinkering with a program.
But, I have a little time this Holiday weekend so I'll see if I can make myself useful for a change.
(I can't make any promises, wish I could).
Can you attach here one of those .tbl files so we can have a look?
Here is a copy of my tool.tbl, renamed to .txt so as to be able to upload it...
- tool.txt
- Rename to tool.tbl
- (2.8 KiB) Downloaded 102 times
Looking at 0.19 it seems the file mentioned above by sliptonic is gone and there are now two files of interest?
PathToolLibraryEditor.py
PathToolLibraryManager.py
Also pertinent to this: https://forum.freecadweb.org/viewtopic. ... c+tool.tbl
