TL;DR
-- Freetype: 2.10.4
-- OpenGLU: /usr/lib/libGLU.so [/usr/lib/libGLU.so][/usr/include]
-- Coin3D: [Coin] []
-- SPNAV: [/usr/lib/libspnav.so] [/usr/include]
-- Freetype: 2.10.4
message(STATUS "Coin3D: [${COIN3D_LIBRARIES}] [${COIN3D_INCLUDE_DIRS}]")
Nice. It's weird that in comparison to other Find*.cmake files, like matplotlib
-- Coin3D: 4.0.1 [Coin] [ ]
pkg_check_modules (COIN3D Coin)
-- Coin3D: [/usr/lib/libCoin.so] [/usr/include]
Can anyone answer this?
@greyltc Do you mind testing?
-- Checking for one of the modules 'hdf5-serial'
-- Unable to determine HDF5 C flags from HDF5 wrapper.
-- Unable to determine HDF5 C version_var from HDF5 wrapper.
-- Found HDF5: hdf5::hdf5-shared;hdf5::hdf5-shared;/usr/lib/libhdf5.so (found version "1.12.0")
-- Checking for one of the modules 'ompi-cxx'
-- Found SWIG: /usr/bin/swig (found version "4.0.2")
-- Found Eigen3: /usr/include/eigen3 (found suitable version "3.3.9", minimum required is "2.91.0")
-- Checking for module 'Coin'
-- Found Coin, version 4.0.1
-- Coin3D libraries found
-- Found Spnav: /usr/lib/libspnav.so
-- Shiboken2Config: Using default python: .cpython-39-x86_64-linux-gnu
-- Found PythonInterp: /usr/bin/python (found suitable version "3.9.2", minimum required is "3")
