Pull Requests forum clean-up
Post by NormandC »
As you can see and on shoogen's request, I created an Archived Pull Requests sub-forum.
I cleaned up the forum and only kept the pull requests that had not been processed, or had been postponed. The remaining ones fit in a single page which will make them easier to manage.
Please have a look at the topics without tags, as I'm unsure of their status. I bumped a few of them.
Thanks!
Re: Pull Requests forum clean-up
Post by NormandC »
I just had a thought: instead of a single "Archived Pull Requests" sub-forum, would it be better to have many?
  • Merged
  • Postponed
  • Abandoned/Rejected
That way the postponed pull requests would not be in the main Pull requests forum. We could even stop adding tags to the topic titles.
Post by yorik »
Hmm it's a very good idea actually... Moving a topic to another forum is even simpler than editing the title...
Post by NormandC »
Thanks for your reply, Yorik. Since you're the only one who bothered to, I guess I will leave it at that. It's not like I have any use for this forum.
abdullah
Post by abdullah »
normandc wrote:Thanks for your reply, Yorik. Since you're the only one who bothered to, I guess I will leave it at that. It's not like I have any use for this forum.
If you want the newbie's point of view. I agree with Yorik. For me it would be much more clear...
Post by NormandC »
Thanks Abdullah. So that makes two votes for having more subforums to sort the pull requests.
tanderson69
Post by tanderson69 »
I like it.
jmaustpc
Post by jmaustpc »
tanderson69 wrote:I like it.
Do you mean the way Norm has currently set it up.....or do you want more sub forums?
normandc wrote:I just had a thought: instead of a single "Archived Pull Requests" sub-forum, would it be better to have many?
  • Merged
  • Postponed
